| A8 / S8 (D2 Platform) Discussion Discussion forum for the D2 Audi A8 and S8 produced from 1994-2002 |
#1 | ||
#2 |
Member
Look at the ps pump then follow the high pressure line into the tube like part of the frame.. it goes down the the rack.. this pipe usually leaks from withing the foam type surround.. try pulling the surround back a few inches it should all be gushing out.
-Jack 2006 Chrysler 300C 5.7 AWD 97 A8q 123k miles (GONE BUT NOT FORGOTTEN) --ALUMIN8-- 300HP and 3.06 Ghz of power Normal by day ![]() Stealth By night
#3 |
Thanks for the tip.
#4 |
leaking at the clamp at the resevoir. That allowed fluid to seep down the underside of the hose and drip onto the anti-lock brake unit. At first, I thought a brake unit seal or line had gone bad. A simple re-clamp of the connection at the resevoir cured it for me. Good luck.
#5 |
Member
If there is no fluid ouside, anywhere, after careful examination I imagine you will find it if you loosen a rack boot.
The place below sells racks for $425 but I know nothing about them. Perhaps someone can advise you. |
#6 |
is a LOT of fluid- it HAS to be visible somewhere under the car! I purchased a rebuilt rack for $400 and replaced it myself- 5 hours of pure hell! I wouldn't recommend doing the rack yourself unless you are a really good mechanic and a masochist. However, $1100 for 5 hours work is pretty good pay......
Have your mechanic check both outer ends of the steering rack- I bet that's where your leak is if the hoses are all OK. |
#7 |
My bet is you are correct. I have some drippage under the right end, but only a few drops a night. I definitely have an acrid smell from the right wheel well when I pull in to garage. My guess is a pin hole sparying up onto the exhaust manifold during high pressure build ups ( turning into my garage?) I can buy a lot of fluid for the price of fixing this leak. My big concern is what other damage is it causing and will I eventually get a catastrophic failure of the steering - not a good thing.
| Tags |
| 98, a8, leak, power, steering |
