Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D2 Platform) Discussion
Old 11-18-2003, 07:18 PM   #1
gworrel
Default 2001 A8L vs A8 wheel sizes
I have been looking for winter wheels for my 2001 A8L and was surprised to find today that many wheels that will fit the A8 will not fit the A8L. At least that is what the Tirerack web site suggests. When I search on their web site for 17" wheels for the 2001 A8L I get only 15 choices, but the A8 shows 52 options. I asked on the wheel and tire forum and Gary@tirerack.com said he thinks it is a brake clearance issue.
When I check 18" wheels, the A8 has 52 options, the S8 has 29 options, and the A8L has only 27 choices. This does not seem right. Is it possible a wheel that fits on the S8 would not fit on the A8L?
I want to use the Blizzak WS-50 which is not offered in anything larger than 17" sizes. I have been looking at wheels on eBay and elsewhere but now I am concerned about buying any wheel not specifically tested on the A8L.
Greg Worrel
gworrel is offline   Reply With Quote
Old 11-18-2003, 09:20 PM   #2
chucklane
Default Re: 2001 A8L vs A8 wheel sizes
That odd very odd. The S8 has the biggest breaks out of the 3 and i believe the A8L's are a bit bit bigger than the A8's there is no reason why the 18's on the A8 shouldnt fit the A8L. Hec the standard wheels for the A8L where only 17's. Furthermore you could even get 16's in Europe i believe.
chucklane is offline   Reply With Quote
Old 11-19-2003, 03:37 AM   #3
PaulW
Default As far as I know, the brakes on the A8 and A8L are the same
Just seems that the tirerack.com is not correct.
17" wheels with et 48 to 35 should work just fine. Heck, I have my Porsche brakes under the stock 17" wheels no problem.
pw
07 S8
PaulW is offline   Reply With Quote
Old 11-19-2003, 05:33 AM   #4
gworrel
Default The brakes are not the same
I don't know if it would make a difference in wheel fitment, but the brake discs are larger on the A8L.
From the Audiworld Tech historical guide for 2001:
Front, size and type:
A8: 12.3 in. (312 x 25 mm) - Ventilated disc A8L: 12.7 in. (323 x 30 mm) - Ventilated disc
Rear, size and type:
A8: 9.6 in. (245 x 10 mm) - Solid disc
A8L: 10.6 in. (269 x 22 mm) - Solid disc
The standard wheel was 7Jx16in for both A8 and A8L
Old 11-19-2003, 05:37 AM   #5
PaulW
Default Didn't know that
But my front brakes are 332 x 32mm and they still fit, have huge calipers too. I don't want to say any 17" wheel will fit, but I'll bet a paycheck that anything with a offset of 48 to 35 will.
Ebay always has a lot of A4 and A6 take offs for sale, but you'll need different size tires....but you already are getting new ones.
pw
07 S8
Old 11-19-2003, 07:01 AM   #6
chucklane
Default ohh no paul caght off guard! hehe. Yeah they gave the A8L bigger breaks b/c of weigh i think?
Old 11-19-2003, 07:22 AM   #7
CA_A8
Default yikes...solid disks in the rear?????
...and that info from an 'official' spec sheet? Have a look at your rear discs - they look solidly made, but also well ventilated!
CA_A8 is offline   Reply With Quote
Old 11-19-2003, 07:22 AM   #8
ryoung
Elder Member
Default Re: A8L vs A8 vs S8 wheels
I can understand why a wheel that would fit the A8/A8L would not fit the S8, but I can't understand the difference between the A8 and A8L for a 17" wheel.
A8 - 12.3" (312 mm) rotor with 16" wheel and sliding caliper
A8L - 12.7" (323 mm) rotor with 16" wheel and sliding caliper
S8 - 13.6" (345 mm rotor) with 18" wheel and fixed caliper
My S8 - 14" (355 mm) rotor with 18" wheel and fixed caliper
First consider wheel rim and caliper interference resulting from rotor diameter changes. With one caveat, I could fit a 17" Avus wheel over my Alcon calipers on the 14" rotor. It would be VERY close, but it would fit. The caveat: It's so close that a stick-on wheel weight would hit the caliper if they're in the same plane. If I could (barely) fit a 17" wheel over a 14" rotor, I can't imagine that an A8L caliper on a 12.7" rotor would hit the rim.
Then there's the problem of caliper - spoke interference, which is the reason for the difference between the A8/A8L and the S8 wheel options. With the sliding caliper of the A8/A8L, the single piston is located on the inside of the rotor and away from the wheel. With fixed calipers, you have opposing pistons on both sides of the rotor. The difference is apparent in these pics.
The result is that even if there's no problem with rotor diameter, the "thicker" outside portion of a fixed caliper may hit the spokes of a wheel that would clear the A8/A8L's sliding caliper. I suppose it's conceivable that moving a sliding caliper out 0.2" on the A8L could cause a problem with a wheel's spokes, but this seems extremely unlikely.
My conclusion: Tirerack is in error. The 17" A8 wheels will fit an A8L.
2001 Audi S8
2007 Toyota FJ Cruiser
ryoung is offline   Reply With Quote
Old 11-19-2003, 07:28 AM   #9
PaulW
Default Never seen an A8 with vented rear discs, maybe the A8L has them
07 S8
Old 11-19-2003, 09:56 AM   #10
KaMaKaZieP -ALUMIN8-
Member
Default So can we put the A8L brakes on the A8 with just a caliper bracket change?
-Jack
2006 Chrysler 300C 5.7 AWD
97 A8q 123k miles (GONE BUT NOT FORGOTTEN)
--ALUMIN8--
300HP and 3.06 Ghz of power
Normal by day
Stealth By night
KaMaKaZieP -ALUMIN8- is offline   Reply With Quote
18, 19, 2003, 24510mm, 300c, 345mm, a8, a8l, audi, diameter, fit, offset, reps, rotor, rotors, wheel, wheels
