Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D2 Platform) Discussion
Old 08-31-2003, 09:35 PM   #11
skiwi
2008 Audi RS6
Default controlling the tranny by tip in "drive" mode
it has been suggested that the 2nd digit controls the use of the steering wheel tip controls while the tranny is in non-tip mode (i.e. in drive). the later cars have this function - as did the 2003 a4q i drove last week.
this doesn't work on my car, although the tranny will take the code.
my 01 s8 is, as far as i can tell from the bentley wiring diagrams, a usa '02 model - so i'm very interested in your experiences.
dave
'03 rs6
'04 allroad tdi
skiwi is offline   Reply With Quote
Old 09-02-2003, 11:45 AM   #12
Maxster4.2
Default Re: controlling the tranny by tip in "drive" mode
Bad news, I Just got a chance to re-check my recoded Trans and it looks like the 00032 does not stay after turning the car off (the Trans has defaulted back to the 00102).
05 Ming Blue A8L
01 Ming Blue S8
Hardwired Valentine V1
(More Faster......}
Maxster4.2 is offline   Reply With Quote
Old 09-02-2003, 12:43 PM   #13
skiwi
2008 Audi RS6
Default same here
you need to check after recoding the transmission. if will always seem to "accept" the coding, but a unacceptable code will not "stick".
dave
'03 rs6
'04 allroad tdi
Old 09-21-2004, 11:16 AM   #14
dimitristx
Default Same here; 00032 would not "stick". I'll try skiwi's 00101
2001 Audi S8
2007 Audi S4 Cabrio
2004 Lexus GX470
2006 Saab 93 Aero Cabrio
dimitristx is offline   Reply With Quote
Old 05-02-2012, 12:28 PM   #15
morpheousx
Originally Posted by Maxster4.2 View Post
The car came with the TCM coded as 00102 but it does not have the S mode on the shifter like the 2002 and later Tiptronic transmissions. I did this on my A6 4.2 and loved the difference (Holding all Gears).
I also recoded the Central Locking Module to One Touch Unlock & Window/Sun Roof closing and opening from the remote.
Can you please,tell me what is the code for the "Central Locking Module to One Touch Unlock & Window/Sun Roof closing and opening from the remote" via vag-com?
I want this feature enabled on my 2001 Audi S8,i have it enabled on my 2001 Audi A4 B5,i tried the same code i used on 2001 A4 B5 on my 2001 Audi S8 and it didn't work.
The code you used to program your central locking module,will it work for mine or every 2001 Audi S8 with a different Vin# has its own code to unlock this feature?
I am curious to know if the code you used is universal or i have to use some sort of chart,to make or create my own code.
Please let me know ASAP. Thank you,friend.
morpheousx is offline   Reply With Quote
Old 05-02-2012, 02:19 PM   #16
silverd2
silverd2's Avatar
A8 and S8 have a different set of codes for this.
You can even do this with the simple free version of VCDS-Lite...I did. Works the same on all D2 A8's and S8's >>>>
http://forums.quattroworld.com/a8/msgs/31839.phtml
Mine: '01 A8 SWB
Hers: '03 Allroad 2.7T
Dog's: '90 Passat wagon
silverd2 is offline   Reply With Quote
Old 05-02-2012, 02:38 PM   #17
morpheousx
Could you just post the code you programmed your module,just to make life easier? I have a full version of the vag-com software,so i don't need the lite version.
I only need the code to program the central locking module. ^_^
Thank you for responding by the way.
Old 05-02-2012, 02:54 PM   #18
morpheousx
Quick update: I think i understand the chart now. I see the codes and to the right,i see the list of features they represent. So if i want "one touch,auto lock,remote window control,no horn honk,i recode to "15208" correct?
What code would i enter,if i want"one touch,auto lock,remote window control,HORN HONK" what would i enter? I don't know how to create a custom code as i don't understand the conversion chart.
Please advise....
Old 05-02-2012, 05:39 PM   #19
silverd2
silverd2's Avatar
Don't know why, but the base code seems to be 15108, which is the sum of the values in columns 8,9,11,13 & 14. The codes listed are the values listed under the functions listed added to that code.
I use code 16204 >>> Base (15108) + horn honk (1024) + remote window (64) + safety lock (8) which equals 16204...and works that way. All the codes listed add up that way.
So what you're looking for should be code 15208 + horn honk (1024), which should be code 16232.
Please let us know if that works...it should(?). If so, then other combos other than those listed should be possible...except that you must choose between one touch(4) or safety lock(8), but not both added.
So I should be able to add "auto lock" by simply adding 32 to my present code, equaling 16236. I'll try that soon and get back to you.
Mine: '01 A8 SWB
Old 05-02-2012, 06:20 PM   #20
morpheousx
I'll try that and get back to you. Thank you much,for helping me out on this.
I goggled for hours and couldn't find **** on coding the central locking module for a 2001 Audi S8.
00032, 00102, 2001, 2002, 2003, allroad, audi, blue, faster, ming, program, recode, s8, tcm, transmission
