Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D2 Platform) Discussion
Old 04-18-2003, 09:36 AM   #1
docmusolf
Member
Default $49.95 for break fluid from the stealers. Holy Sh#T!!!!!!!!!
What other brands will work?
Brent
docmusolf is offline   Reply With Quote
Old 04-18-2003, 10:04 AM   #2
ryoung
Elder Member
Default Re: what other brands will work
For that price, you might as well get Castrol SRF; it's what I use, but it's even more expensive and probably hard to find on short notice.
Brake fluid is another one of those things where it seems everyone has a different opinion. An AudiWorld search on "Brake fluid" turned up 2900 hits! As long as you use a DOT 4 fluid and change it every two years (or bleed brakes regular, like at track events), most any brake fluid is OK. See the link, but Valvoline High Performance Synthetic seems to be an economical good performer. Just be sure you definitely get a DOT4 brake fluid.
2001 Audi S8
2007 Toyota FJ Cruiser
ryoung is offline   Reply With Quote
Old 04-18-2003, 10:15 AM   #3
ryoung
Elder Member
Default On another brake related subject ...
If your '99 A8 is still running with the original rotors at 60k miles, they're probably rusted solidly to the hubs.
This weekend, it would really help if you pulled the wheels and sprayed a little bit of penetrating oil on the hub where it meets the rotor. [Don't overdue it; you definitely don't want oil on the swept area of the rotor or the pads!] Even so, we're still probably going to need a solid wack from a hammer to break the rotor free at Grattan, but hopefully a week's exposure to penetrating oil will have loosened things up somewhat. When we replace the rotors, we'll put some brake caliper grease on the hub to prevent this from happening again. And as you said, hopefully only the rear rotors need to be replaced.
2001 Audi S8
Old 04-18-2003, 10:45 AM   #4
docmusolf
Member
Default The front look like they have been replaced, rears look original
Old 04-18-2003, 12:07 PM   #5
barryl
Default available near you
Hey,
Good brake fluid that you can probably find would be
1. Valvoline Synthetic. It's not really synthetic, but it works and has a
high boiling point.
2. Ford HD Brake Fluid. Should be at any FoMoCo dealer. Cheap, works
well.
3. Castrol GT-LMA would do in an emergency.
How much time do you have? You could order a pint of Ate fluid
from any number of places, Paragon Products comes to mind, and
have it in 3 days.
Barry
barryl is offline   Reply With Quote
Old 04-18-2003, 12:20 PM   #6
JimR
AudiWorld Uber User
Default Re: Valvoline Synthetic
That's what I used on the A6 when Ray and I pulled the big 60k maintenance 6+/- weeks ago, and I'm about to do the A8 with.
JimR is offline   Reply With Quote
