requesting diagram of engine cooling system(radiator hoses).
Old 01-26-2009, 05:43 PM
S2000driver's Avatar
Default requesting diagram of engine cooling system(radiator hoses).
hi everyone, i am a newly registered member and i have a question about my wife's audi a6. her engine coolant is leaking from the rear center of the engine and her fuel/emission hose is disconnected. i jacked up the car to see where it belonged, but there is to many parts obstructing my view. can anyone provide a diagram of the engine cooling system? it would be very appreciated!
Old 01-26-2009, 05:52 PM
Tech Guru
4Driver4's Avatar
Default Howdy.
What engine do you have? 2.7 with a leak like that is usually the aux coolant pump.
Old 01-26-2009, 06:13 PM
Default Re: Howdy.
i'm not 100% on the liters of the engine, but i do know that the pannel on the motor reads "v5". so, where in the engine bay can i find that aux coolant pump? is it by chance located next to the firewall? does the fuel/emissions hose connect to the pump? thank you for your help. great forum so far!
Old 01-26-2009, 06:19 PM
GBW
GBW's Avatar
Default Look like this?
<center><img src="https://www.audiworld.com/tech/pics/eng63-01.jpg"></center><p>
Old 01-26-2009, 06:21 PM
GBW
GBW's Avatar
Default If so....
Here's a DYI description, about $900 at a dealer...replace the hoses while you're there...<ul><li><a href="https://www.audiworld.com/tech/eng69.shtml">Read this....</a></li></ul>
Old 01-26-2009, 06:23 PM
Grapeking's Avatar
that would be my guess based on the description.
Old 01-26-2009, 06:38 PM
Default Re: Look like this?
her car doesn't have that engine, but maybe the hose connections are the same.
Old 01-26-2009, 06:40 PM
Default Re: that would be my guess based on the description.
thanks for the input on my problem!
Old 01-26-2009, 06:42 PM
Default Re: If so....
wow, thanks for the info.
Old 01-26-2009, 07:07 PM
GBW
GBW's Avatar
Default So she has the 2.8....no turbos?
I don't think the 2.8 has the aux coolant pump...can anybody confirm?
Quick Reply: requesting diagram of engine cooling system(radiator hoses).
