WRITEUP: 2.7T Secondary Air Injection SAI Pump rebuild
Old 05-25-2008, 03:38 PM
halik's Avatar
Default WRITEUP: 2.7T Secondary Air Injection SAI Pump rebuild
If you're getting insufficient flow CELs P1423 P141 1, some part of your SAI system is faulty. In my case the pump itself was seized up - you can do a simple check by running 12V directly to the pump. It should blow air like a regular hair dryer. Also check the air pump fuse (40A in the ECU box), mine was blown. In any case, new pumps run around $400, so rebuilding is the preferred way to go.
Tools needed:
- Metric socket set
- Torx bit set
- PB Blaster
- Engine Degreaser/Carb cleaner
- Rust Remover spray
- Chain lube or something similar
1) Start off by removing the Ypipe and then unplugging the rubber/plastic T tube that connects the SAI pump to the combi valves. Unplug the electrical connector on the pump.
2)Undo the two 10mm bolts that hold the SAI pump bracket to the plenum. Also loosen the 10mm nut that holds bracket on the right side (kind of a pain to see). Now you should be able to wiggle the pump out of the bay.
EXPLODED VIEW:
3)Remove 3 round clips off the bottom of the pump and the bottom ring with the filter should come off (top right in the exploded view)
4)Remove 5 metal clips that hold the main assmebly together. Now the bottom half should come off (top, second from the right)
5)You should be looking at something like this:
Use cir clip pliers to remove the clip and then spray down the nut with PB Blaster. Give it 5 minutes to soak up and then remove the nut with a wrench and a screw driver.
6)Remove the small brass spacers and the first impeller/fan. The big black impeller (second from left, top) should now come off also
7)Spray a ton of PB Blaster on the long spacer, wait and then pull it off. It helps to use two wrenches for leverage. Once the spacer is off, the second impeller should come off
8)Unscrew the two Torx screws and pull the motor out:
As far as rebuilding goes, I used a combination or PB Blaster, Rust Remover, Carb Cleaner and Chain lube (in that order) to get it spinning freely. The motor in my pump was all sorts of rusted, so I used the rust remover was the key... but YMMV. It's a good idea to test the motor using the car battery to make sure it's actually working.
Also I used a bunch of RTV silicone to seal the motor from the rest of the assembly, hopefully this will keep the moisture away.
Finally a reference of how all the parts go together:
EDIT Feb-2010:
Year after the rebuild the pump crapped out again. The issue, as it turns out, is the bearing in the front of the pump motor( the bulge in the front face of the motor). Interestingly enough you can find a replacement bearing in any hardware store - I was able to remove the old one and replace it with a 1/4" (if i remember correctly) bearing from Ace Hardware. Just take the pump motor with you to the store and buy the bearing that fits EXACTLY on the output shaft of the motor. Year later I'm problem free.
Old 05-25-2008, 03:48 PM
TurboRambo's Avatar
nice work!
Old 05-26-2008, 05:05 AM
audifirst's Avatar
would code 16795 be part of this pump as well ?
Old 05-26-2008, 09:44 PM
OneGuyInCA's Avatar
Default So being that yours was seized up... I guess you wouldn't be able to tell me if
yours made a high pitch "dentist" drill noise when it ran?
How about... now that you fixed it... does it make any high pitch dentist noise or none at all?
After ready many different posts.... I'm guessing that the SAIP is suppose to run pretty quiet... unless it's heading south.
Nice work btw!!
Old 05-27-2008, 05:43 AM
halik's Avatar
Yeah it squeals quite a bit
Old 02-06-2010, 01:46 PM
alonkut's Avatar
Default thanks for this well labeled post!!.. 1 question...
what was your procedure for getting to the bearing that you needed to replace? Do you mean the one at the base of the shaft?
Tools needed:
- Metric socket set
- Torx bit set
- PB Blaster
EXPLODED VIEW:
EDIT Feb-2010:
Old 02-06-2010, 03:14 PM
halik's Avatar
I ended up cutting into the metal face of the motor to expose the outer race of the bearing and then hammered it out. It was the bearing closer to the impellers that crapped out.
Old 03-09-2010, 07:47 AM
badinstincts's Avatar
I would love to do this rather than spending $300 on a new pump.
just want to know if I could still use the car while this is out. Do I need to plug the hose or not?
also, it would have been nice to know where you cut the hole in the motor to get that bearing out. a pic would have been great or maybe you can show exactly where in one of your pics, circle it or something...
Old 05-11-2010, 09:45 AM
vponomar's Avatar
Default Guys, what is the part number for SAP for 2.7tt? Mine is 04.
thanks.
Old 05-20-2011, 03:41 PM
rockcreek7's Avatar
How did you remove the third 10mm bolt holding the bracket?
Is the third bolt in the area in yellow?
Thanks for your help
Quick Reply: WRITEUP: 2.7T Secondary Air Injection SAI Pump rebuild
