Old 08-15-2016, 03:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C5) Air Intake and Exhaust Guides
Print Wikipost
Intake Air Temp. Sensor (G42) IAT Replacement
Old 12-12-2006, 10:10 AM
iProDrive's Avatar
Default Intake Air Temp. Sensor (G42) IAT Replacement
After my <a href="https://forums.audiworld.com/a6/msgs/661880.phtml">Suction Pump Replacement</a> and my <a href="https://forums.audiworld.com/a6/msgs/663021.phtml">Brittle Broken Hose</a>, I thought I had solved all of my problems. Sure enough...I was wrong! I kept pulling this code below:
16496 - Intake Air Temp. Sensor (G42): Signal too Low
P0112 - 35-00 - -
Didn't matter what I did it always came back within three seconds of clearing it. So I knew something was up. I followed some steps out of my Repair manual. I read the value of the Intake Air Temperature (IAT) and it was at a solid 143 degrees Celsius.
approx. 143 ° C
Short circuit to Ground (GND)
approx. -40 ° C
Open circuit or short circuit to B+
So I pulled the IAT out and the value did NOT change. I unplugged the sensor and the value did NOT change. I cleaned the connector and made sure the wires were in good condition, plugged it back in and the value did NOT change. I figured I would need a new sensor. Got online to <a href="www.worldimpex.com">World Impex</a> and ordered a new sensor. It was here in a timely matter considering it was shipped from NJ to UT. I have ordered from World Impex before in the past they are great! I will continue to get OEM parts from them I got the new sensor and was eager to install it. Took less than 15 minutes with all the tools out and clean up. Pics of the install below...
Got my trusty Husky torx tool out.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY2000AudiA6/IAT/1.jpg">
Started to remove the bolt.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY2000AudiA6/IAT/2.jpg">
Closer shot of removal.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY2000AudiA6/IAT/3.jpg">
Unplugged the connector.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY2000AudiA6/IAT/4.jpg">
Connector removed.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY2000AudiA6/IAT/6.jpg">
Comparison between old and new sensor.
[Old sensor left, new sensor right.]
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY2000AudiA6/IAT/5.jpg">
New sensor installed.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY2000AudiA6/IAT/7.jpg">
Plugged the connector back into the new sensor.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY2000AudiA6/IAT/9.jpg">
Now this is where it gets interesting. AFTER I installed the new sensor and plugged in my laptop. I was <b>STILL</b> getting the same error! So after some careful thought about how this problem could still be here, I came to this conclusion: I was in a real hurry installing the suction pump because it was starting to rain and my garage was currently occupied. That's how I broke the <a href="https://forums.audiworld.com/a6/msgs/663021.phtml">brittle hose</a>. It's alright, I won't work on my car that fast ever again. I always set aside a good lot of time now . Anyways, long story short I had switched the plugs. The blue plug was suppose to be to the left and the gray plug was suppose to be on the sensor. The plugs <b>SHOULD</b> be plugged in like the picture below:
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY2000AudiA6/IAT/10.jpg">
Nonetheless I had a replaced a sensor that probably didn't need replacement.
All in all one brand new sensor and one "stupid" moment.
Hector Nyambiya (12-14-2020)
Old 12-12-2006, 10:21 AM
saabSean's Avatar
Default That's a nice little experiment
That's the kind of thing that I may not have figured out and then felt silly about when the mechanic figured it out for me.
The little successes feel just as good as the big ones, though, so congrats!
Old 12-12-2006, 10:50 AM
iProDrive's Avatar
Default Thanks you! =] I was happy to figure it out...otherwise...
Would have resorted to duct tape over the engine light LOL!
Old 12-12-2006, 10:58 AM
Grapeking's Avatar
Default thanks for posting that, it is a good reminder about working while rushed. I'm surprised
you ordered a new sensor when the fault continued even after you had disconnected the plug from the original sensor. Am I missing something?
Old 12-12-2006, 11:01 AM
iProDrive's Avatar
Default I actually had just ordered the sensor and then ran the diagnostics...it was a busy Monday...
It was a fairly cheap part. Didn't really matter. I didn't want to run the diagnostics and then find out I needed a sensor anyways. Just wanted to get the part to me a day ahead Who knows...the sensor could have really gone bad and I switched the plugs after. Like I said before, all in all in works now and I have a new sensor.
Old 12-12-2006, 12:05 PM
Grapeking's Avatar
ok, just wondering, I can certainly understand your logic!
Old 12-12-2006, 12:42 PM
iProDrive's Avatar
Wasn't too fond of posting a complete mishap on my part figured I would post to perhaps help others
Old 10-13-2013, 03:57 PM
fusion1127's Avatar
Default 2001 D2 S8 air intake temp (I.A.T) sensor location
Where is the air intake temperature sensor located on a 2001 Audi S8?
Eng:4.2L
Old 10-13-2013, 04:56 PM
tester123's Avatar
Eng:4.2L
If you have 4.2 engine, most likely it's the same as mine and the intake temp sensor is integrated into Mass Air Flow sensor. In other words, replace MAF if IAT is bad.
Old 10-13-2013, 06:12 PM
fusion1127's Avatar
Default D2 IAT
thanks, am trying to add a performance powder chip thu the IAT sensor, is this possible?
Quick Reply: Intake Air Temp. Sensor (G42) IAT Replacement
