Anyone with experience of tranny/TC code 17125?
Got a 'sporadic DTC' of 17125 from the TCM during investigation of a 18032 (transmission turns on the MIL/CEL). My indy tech tells me not to worry, he reset it and wants to wait and see if it recurs. But.. STFA yields two contrasting prognoses:
1. Allroad forum: frightening stories of torque converter replacement and transmission failure following shortly after this code first appears. Grim, $$$, urgent investigation needed.
2. An Audi TSB quoted in the A6 forum:
TECHNICAL SERVICE BULLETIN: MFG Bulletin Number: 320501 Date: 20051025
Component: POWER TRAIN
Details: MIL ILLUMINATED, DTC 17125 STORED IN TRANSMISSION FAULT MEMORY-NO DRIVEABILITY CONCERN. TORQUE CONVERTER CLUTCH CIRCUIT PERFORMANCE OR STUCK OFF STORED IN TRANSMISSION FAULT MEMORY. *SC
Internal use: 20051114
So I have no idea whether to freak or not. My friendly tech consulted his VAG OBD stuff and found a possible culprit, pressure control valve 4 -N218- (also known as solenoid valve 7 -N94-), but serious investigation of this issue will cost downtime, car rental, and moola.
Anyone with thoughts on the relevance of this TSB, which basically seems to tell us 2001 A6ers to ignore this code?
Helps!
Helps!
Ordered the relevant TSBs
A320501 TB AUDI MIL ILLUMINATED,DTC 17125 STORED 1 $4.00 $4.00
A320502 TB AUDI MIL ILLUMINATED,DTC 17125 STORED 1 $2.00 $2.00
Tax $.44 Total $6.44
Available at the Audi literature ordering site <a href="http://www.audi.ddsltd.com/cgi-bin/default?ACTION=START&USERTYPE=C&COMPANY=AUDI"> here. </a>
They also have 'Audi-official' CD-based repair manuals for $100. Not sure how these compare to the Bentleys but I ordered the C5 A6 item for the hell of it.
Will report on what the TSB sez, but it's sent hardcopy, unfortunately not PDF.
Text of the TSB (bad news for 17125 codes: replace TC)
TSB C 32-05-01 (and 02) dated 10/25/05
Models A6, Allroad w/2.7T (engine code APB, BEL, auto transmission), 2001-2004, to VIN 4B_4N024000
MIL ILLUMINATED, DTC 17125 stored in transmission fault memory
Condition: Malfunction Indicator Light [check engine] on, DTC 17125 "Torque converter clutch circuit performance or stuck off" stored in transmission fault memory
May be caused by torque converter internal oil seal failure
Service: Torque converter must be replaced. Internal torque converter seal is not replaceable.
... [transmission removal reference]
... [torque converter replacement reference]
Production: Vehicles after VIN 4B_4N024000 are fitted with an improved torque converter.
Only improved replacement parts are available from your Parts Depot.
rohit13
09-11-2011 03:29 AM
Pchelka01
08-05-2011 02:58 PM
