Side sunshade hooks FINALLY installed today!
AudiWorld Expert
After a funeral this AM, my son's preschool called to have me pick him up since he had a fever. While he was resting, I took the opportunity to install the sunshade hooks. Sorry, I do not have pictures of the rear door panel swap, which was done a while back.
Anyway, for anyone lucky enough to source OEM rear door panels with the integrated sunshades, here is how to align the hooks properly. I think someone else here will be doing this soon, so I figured I would post the process here ))
Oddly enough the hooks that I had I pirated out of my 2001 2.7T before I listed it for sale. The ETKA lists the following part numbers for the sunshade hooks and assorted hardware:
4B0 861 337 B 01C [hook x 4]
4B0 861 359 A 01C [base x 4]
N 013 966 26 [screws x 8]
However, my OEM hooks from the 2001 2.7T were not the same. It was one part, molded plastic, no "base" to speak of, with a different part number: 4B0 861 B RBU. However, none of my on-line parts sources found that any such part number exists...odd...
Here is a closeup of the hook...
<img src="http://img.photobucket.com/albums/v739/hliu55/sunshade/sunshadehookfront.jpg">
...and the back (note the part number)...
<img src="http://img.photobucket.com/albums/v739/hliu55/sunshade/sunshadehookback.jpg">
Here is the sunshade pulled up into position, and some blue painters tape to mark the outer edges of where the hook fastens:
<img src="http://img.photobucket.com/albums/v739/hliu55/sunshade/sunshade1.jpg">
Now I lower the shade, align the hook, and using an awl, mark where I need to drill for the two screws:
<img src="http://img.photobucket.com/albums/v739/hliu55/sunshade/sunshade2.jpg">
Using a tungsten coated drill bit, I made the two holes:
<img src="http://img.photobucket.com/albums/v739/hliu55/sunshade/sunshade3.jpg">
...and installed the hook:
<img src="http://img.photobucket.com/albums/v739/hliu55/sunshade/sunshade4.jpg">
<img src="http://img.photobucket.com/albums/v739/hliu55/sunshade/sunshade5.jpg">
I repeated this step until all 4 hooks were in place (two per side).
Here is the shade up (window down for better view):
<img src="http://img.photobucket.com/albums/v739/hliu55/sunshade/sunshade6.jpg">
Here is a pic of the rear window without the shade up...
<img src="http://img.photobucket.com/albums/v739/hliu55/sunshade/sunshade7.jpg">
and now one with the shade up to protect my son's tender eyes from the sun...
<img src="http://img.photobucket.com/albums/v739/hliu55/sunshade/sunshade8.jpg">
If I have a chance, I'll pull out the other door panels I have in the basement so I can do a supplement to this writeup for the rear door panel removal and install.
P-chop dork ;-)
I used to have some skills, then I sat down at a buddies computer with the latest version, and realized that I have NO CLUE what I'm doing in the new versions... Ohh well, suppose I'll pick it up again one of these days.
Your new cigs pretty awesome. I think it's the most creative I've seen so far...
