Old 12-13-2004, 04:06 PM   #1
OCDboy
Account #: 76151
Default Update: Water in passenger footwell.
Earlier Post
As I had posted earlier, I had water enter the passenger side footwell during a car wash. On Sunday I spent time investigating the issue. I thought it might be good to post what the issue turned out to be.
There are three clips that secure the plastic cover closest to the windshield as indicated in this photo.
My car was missing two! The center and passenger side. Here's the original post of the pollen filter pointing out the missing securing clip on the passenger side.
During my investigation, it was apparent the cover was not secure. I could easily lift the plastic cover...therefore, it would be easy for carwash blowers to forced water down through the gap.
So, my fix was to find a temporary solution to secure the cover. A little thought, I came up with two heavy duty paper clips! (until I can get the clips from the dealer)
I was able to attach the two clips and the cover appears to be secure.
In discussing this today with a friend in the business, the thought was that the clips were removed during a maintenance to help gain access to the filter...and not replaced. (Thank you some mechanic in my car's past).
Thanks goodness I have not sustained any damage to date. My car is a 6-speed, who knows what would have happened if it were a Tip with the TCM under there.
Anyway, I'll call the dealer this week and order replacements. If I find anything different out, I'll post another follow-up.
'01 A6 2.7T 6-spd (Ming Blue, Cold, Sport, Premium), 2 x K04, APR Downpipe & Cat-back (where did I leave the Cats anyway?), Bi-pipe, Forge Diverter Valves, Snub Mount, AWE Fueling Kit, RS4 Intercoolers, Stoptech 332 BBK, RS4 Clutch Kit, AWE DTS, Bilstein PSS9 coilovers, H-sport swaybars, Setrab 12x9 Oil cooler with Mocal 180deg adapter plate, 18x8 RS4 DTM Wheels Falken FK-452 (235/40/18), Track: 17" Flik Lex Wheels with Falken rt-615 245/45/17, B&M Short Shift Kit, Samco hose kit, Forge DV's, RS6 Fender Liners, hella smoked tails.
Dyno results 371whp/411wtq!!!
Other Rides
'03 Mini Cooper--Mama's Ride
'87 4000 CSQ--Under construction
Past Rides
'86 Coupe GT--Tornado Red!
'98 Jetta TDI, aka "Chitty-chitty, Bang-bang" (Gone but not forgotten)
'86 CSQ--gave it's life so other could live (chop, chop)
Kansas City Chapter Website
Kansas City Audi Yahoo Group--Local News and Info
OCDboy is offline   Reply With Quote
Old 12-13-2004, 04:25 PM   #2
April
AudiWorld Uber User
Account #: 3127
Default Glad to hear you got to the bottom of it. Makes sure to dry the interior of the car very
thoroughly. I might place a small portable heater in the footwell for a while, and maybe use some large packets of desiccant to pick up any residual humidity. It could get very nasty with mold and/or bad connectors nearby.
April is offline   Reply With Quote
Old 12-13-2004, 04:27 PM   #3
Audeye A6
Account #: 67177
Default Elementary my dear Watson. Nice work :-0
2001 2.7T / 6spd / Cold Weather Pkg. / Premium Pkg.
EPL Custom Tuned Stage III / 93 Oct
Bilstein-HD / B&G Sport Coils / H-Sports
KO4/997 Hybrids, EV14 Inj, ASP MAF
Vast Kevlar Clutch,RS4 PP & Throwout bearing
Autospeed Trans. stabilizer bar
AWE/McNeil Downpipes/graphite rapped
AWE/McNeil Intercoolers
APR exhaust/snub mount
Port/Polished/Ceramic coat exh. mani's
JHM short shifter
Hardwired/stealth V1
Audeye A6 is offline   Reply With Quote
Old 12-13-2004, 04:41 PM   #4
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default Amen to that. You might what to check under the carpet too - see my old post...
The TCU is actually located on the floor even though Audi says "footwell". It is under the passenger's right foot in a three inch deep well - a great spot for water to collect.
4Driver4
Growing old is mandatory; growing up is optional.
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
2003 Mini Cooper S (just because)
1995 Mazda Miata, Superdupercharged(anti-Audi)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
Old 12-13-2004, 04:43 PM   #5
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default I popped a couple of those off on my car last time I changed the pollen filter.
Sometimes they pop off when you stuff the water tray (aka plastic battery cover) back in. I replaced them, but I think I'll take a second look this weekend.
4Driver4
Old 12-13-2004, 04:49 PM   #6
A6Gary
Account #: 49976
Default Glad to hear that you found the problem. Water leak detection can be very frustrating....
It took me over two months to find the leak in a '98 Dodge Ram 1500 Reg Cab PU. The leak was so bad that I had water sloshing around the passenger side footwell.
A6Gary is offline   Reply With Quote
Old 12-13-2004, 04:54 PM   #7
OCDboy
Account #: 76151
Default I just went out to check:
Pulled the glove box and covers. It appears to be dry underneath...however the carpet is pretty wet. We have what appears to be a 10 day dry spell, so I'll leave it all open until it is thoroughly dry.
I would be a little nervous putting a heater in the car anyway!
Thanks as always.
Other Rides
Past Rides
Old 12-13-2004, 05:40 PM   #8
por911
Account #: 53556
Default Staples to the rescue! Great going.
por911 is offline   Reply With Quote
Old 12-13-2004, 06:03 PM   #9
6ULDV8
Junior Member
Account #: 75436
Default Happens all the time, glad you found it.
6ULDV8 is offline   Reply With Quote
Old 12-13-2004, 07:14 PM   #10
Silver A6Dude
Account #: 65135
Default If it keeps happening after this fix check door vapor barriers. BMW's have a MAJOR prob when the
plastic vapor barrier on the door metal is broken - had a friend with the exact problem, and the dealership had removed his vapor barrier to replace a window motor, then forgot to put one back and voila - huge dump of water after rain / wash.
Silver A6Dude is offline   Reply With Quote
1500, 1999, a4, a6, audi, b6, bmw, cooper, dodge, floor, foot, footwell, gm, leak, mini, passenger, suburban, water
Forum Jump
