Transmission code 00032, new(?) trick.
Old 06-25-2003, 11:56 AM
idemo!'s Avatar
Default Transmission code 00032, new(?) trick.
I VAG'd the transmission with code 00032, which I thought would just allow for crisper shifting and the ability to hold first while in tip mode.
Just discovered this new (at least I never saw the topic posted before) feature today. While in S or D mode tap the up/downshift buttons on the steering wheel. Gear display will change from auto to tip and you can now change the gears at will via the buttons. System defaults back to S or D after about 8 seconds; transmission also returns to full auto mode. Handy feature on the freeway.
Old 06-25-2003, 12:21 PM
Senior Member
gdog009's Avatar
Default cool. you wouldn't happen to be in the LA area would you?
i've seen a red 2002 (or newer) 2.7T around on the streets lately...
a rarity indeed.
Old 06-25-2003, 12:52 PM
Stoney's Avatar
Isn't that a standard feature on 2002+? Not part of recode, AFAIK.
Old 06-25-2003, 02:29 PM
idemo!'s Avatar
It never did it before the recode; I tried repeatedly.
Old 06-25-2003, 02:31 PM
idemo!'s Avatar
No, central IL
Old 06-25-2003, 03:40 PM
itacud's Avatar
That was my understanding as well... even read it in some literature somewhere.
Old 06-25-2003, 06:45 PM
AUJ
AUJ's Avatar
My '02 4.2 does all that with factory TCM soft coding.
Old 06-25-2003, 07:06 PM
Sox Fan's Avatar
Default Does this work on 2000?
And is that the code? I will be getting my cable for Vag-com tomorrow so please let me know and I will try it. Thanks
Old 06-25-2003, 07:24 PM
Stoney's Avatar
Perhaps you tried it at RPMs that prohibited the shift?
Old 06-25-2003, 07:48 PM
tsuic's Avatar
Default Confirmed that this works on an '02 S6
My factory soft coding was 01002 and I've never (frustratingly) had the Tip-override feature. I first tried 01032, which had no apparent effect. But 00032 gives me exactly what idemo! describes. Thanks for the tip! (pun intended)
Quick Reply: Transmission code 00032, new(?) trick.
