Does anyone have an exploded view diagram of the 01E transmission?
Section 2
<img src="http://i207.photobucket.com/albums/bb262/PKmode/AudiS4021.jpg">
<img src="http://i207.photobucket.com/albums/bb262/PKmode/AudiS4022.jpg">
Section 2, pinion assembly, much more indepth of section 2. hope this helps
<img src="http://pictureposter.audiworld.com/101281/trans2.jpg">
Input shaft, drive pinion, hollow shaft and internal selector mechanism from bearing plate, removing and installing
Bearing plate
Servicing, Refer to Bearing Plate, Servicing
Selector rod for 5th and 6th gear
Only replace complete with follower for 5th and 6th gear, Refer to 5TH and 6TH Gear, Removing and Installing
Follower for reverse gear
Pulling out ball sleeve, Refer to , Refer to Bearing Plate, Servicing, See Fig. 3
Driving in ball sleeve, Refer to Bearing Plate, Servicing, See Fig. 4
Selector fork for 3rd and 4th gear
Can be replaced individually
Installation position: rib towards follower
Selector rod for 3rd and 4th gear
Only replace complete with follower for 3rd and 4th gear
Input shaft
Disassembling and assembling, Refer to Overhaul Subassemblies,Input Shaft, Disassembling and Assembling
Follower for 1st and 2nd gear
Circlip
Qty.2
Selector rod for 1st and 2nd gear
Only replace together with selector fork for 1st and 2nd gear (secured together by means of a pin)
Hollow shaft
Disassembling and assembling, Refer to Overhaul Subassemblies, Drive Pinion and Hollow Shaft, Disassembling and Assembling
Drive pinion
Locking bolts
Qty.4
For aluminum bolt: 50 Nm
For steel bolt: 70 Nm
Mark installation positions of aluminum bolts and steel bolts; do not interchange
Bearing plate
Input shaft
Circlip
Qty.2
Hollow shaft
Drive pinion
Locking bolts
Qty.4
