I got this Clutch Circuit Performance or stuck off code
17125 - Torque Converter Clutch Circuit Performance or Stuck Off.
P0741 - 35-10 - - - Intermittent
Anybody got an answer to what this code means? I have 2000 S4 Tip tranny
I erased the CEL couple of times but it keeps on coming back up.
Have to mention that I rebuilt transmission about 2 years ago and spent $4,000. Replaced- TC, Valve body, other small dorky stuffs that needed to be replaced... My car runs like S###.. it jerks while im driving & has unstable idle. When I am about to stop at the red light, it makes CLUNK~~~!!! down shifting noise from second gear to first gear.
I guess Im almost stage 2. I have APR chip 93 octane, Milltek Exhaust only and STFA is almost imposs
impossible... I sometimes see valuable information from STFA but most of them are either joke related or not related to the problem I am having... I will try to call some companies tomorrow morning.
I know there is some good info out there. I use to own a Tip A6...
..and was concerned about the very issue you are having, so I did quite a bit of reading on the issue of TCs. My best guess is that it needs to be rebuilt, but it is possible that the fluid is just low. Have you ever cleared the code and noticed when it comes back? I remember that there is something to with the way it comes back in relation to determining whether the fluid level is low, but I'm not 100% sure. Hopefully someone else will chime in...
seanwg
03-16-2018 09:07 PM
2004 allroad caledonia
2.7T V6 Discussion
04-07-2012 05:07 AM
MattKA4
12-19-2004 12:38 PM
2001, a6, audi, circuit, clutch, code, converter, description, ford, p0741, performance, performancestuck, s4, stuck, torque
