Can you mix leaded gas and unleaded gas together?
Old 11-17-2006, 10:29 AM
EdyJun's Avatar
Default Can you mix leaded gas and unleaded gas together?
<center><img src="http://www.vpracingfuels.com/misc_pails.jpg"></center><p>I have no cats. at the moment and want to make sure that I can mix leaded gas and unleaded gas together?
Edy
Old 11-17-2006, 10:31 AM
crew219's Avatar
doesn't leaded gas also kill your O2 sensors?
Old 11-17-2006, 10:32 AM
Gator Al (Al)'s Avatar
Default My understanding is yes.
If you run leaded for too long, you will foul the O2 sensors(?), but it takes a while.
Old 11-17-2006, 10:33 AM
kiNGMak.:.OEM's Avatar
yup... no problem whatsoever
Old 11-17-2006, 10:34 AM
Default Not immediately.
A friend has been running leaded in his dragster Rabbit for a while now, sensors still OK.
Old 11-17-2006, 10:35 AM
EdyJun's Avatar
Default I was told that the old school O2 sensors yes, but not so much the new O2 sensors.
However i would not recommend to run leaded as a day to day gas, the o2s will die eventually.
Edy
Old 11-17-2006, 10:38 AM
krayziekujo's Avatar
Default so long as none of the guys on the forum belong to this agency
<center><img src="http://www.kdheks.gov/kdsi/images/ARD/LOGO%20-%20EPA%20B&amp;W.jpg"></center><p>
Old 11-17-2006, 10:51 AM
ErikS4's Avatar
No. It kills your cats.
Old 11-17-2006, 10:58 AM
bertworks(dan@jhm)'s Avatar
Default i thought leaded gas could mess up your injectors too?
one of my good buddies(who is a car expert) told me they destroy cats, and could mess up your o2's and your fuel injectors, after i was going to fill up with some 110 leaded at the track but then decided not to.
it just sucks that the highest unleaded octane is like 104
Old 11-17-2006, 10:59 AM
Member
Casablanca Avant's Avatar
why would you even want to?
Quick Reply: Can you mix leaded gas and unleaded gas together?
