Re: The Electronic Throttle Control, how do you know when it goes bad? What does the car do?
Old 09-30-2006, 06:40 AM
awdseth's Avatar
Old 09-30-2006, 06:53 AM
AudiWorld Expert
Captain Matt, I be's Avatar
Default EPC light on the cluster, a 'limp mode' of sorts....
if one of the potentiometers on the pedal assembly goes, throttle input should stay pretty normal as the other one will take over - if the actual throttle body goes the car will go into an emergency mode to allow you to get to a safe location to stop. its all in the 2.7T SSP.
Old 09-30-2006, 06:57 AM
awdseth's Avatar
Does it give any symptoms of failing?
Old 09-30-2006, 06:59 AM
Senior Member
-SlowSilverTIPJason-'s Avatar
Default Yes, flashing epc light and crappy throttle response like he said.
If you have VAG you can check the % of each pot in the gas pedal. They're inverted, as in one is 100% while the other is 0% and vice versa. Although you rarely see 100 and 0 for actual numbers. Check that first before you drop big bucks on a throttle body.
FischerWausau
A4 (B8 Platform) Discussion
04-12-2011 06:49 AM
signal11
08-11-2007 01:07 PM
A6Fanboi
12
01-14-2007 09:19 AM
AudiForYou's 2.7T
VAG-COM Discussion
10-06-2004 02:18 PM
scotty slc
10
12-28-2002 01:01 PM
Quick Reply: Re: The Electronic Throttle Control, how do you know when it goes bad? What does the car do?
