(My/RS4/S4) Engine mounts ...............
AudiWorld Expert
Here are my original engine mounts out of my 2002 S4. It seems these are the RS4 P/Ns (8D0199379AD). What is odd, however, is that they have the Brown color code, which matches to 8D0199379Q - I don't know what car the Q's are for.
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03152.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03153.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03154.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03156.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03157.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03158.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03159.jpg">
Here are the new, Audi OEM, Avon, S4 mounts I put in (8D0199379K)
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03137.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03138.jpg">
Here are 4 of the Hamburg-Technic mounts I accidentally ended up with (8D0199379K). Notice the inconsistancy that the far left one comes with the rubber cover, but the others did not:
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03139.jpg">
Here's HT and Avon, side by side:
HT on left. Notice Avon has that apparent ball-valve
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03140.jpg">
HT on left (same writing / P/Ns):
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03141.jpg">
and some install shots:
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03142.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03143.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03144.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/dsc03145.jpg"><ul><li><a href="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/">http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/</a</li></ul>
RS4 Mounts use the same casting, but as long s they have the part number printed on the side...
they are in fact RS4 mounts. You will notice that the HT mounts are in fact massively softer, just flex the top stud sideways and then try it on an Avon RS4 mount. I brought a set of HT mounts and Avon mounts to the SAC GTG and a few people got a chance to compare, not so good for the HT mounts.
Cheers,
Cheers,
AudiWorld Expert
On mine, I replaced due to the mounting bolt spinning...
And that likely happened because I persuaded it to line up as we were putting the engine in place. I should have loosened the top nut on the driver's side - that would have been enough to ease both in.
As it turned out, my old ones needed changing anyway.
Mark P
10
01-31-2006 08:11 PM
Hal_TT::CBP
42
09-08-2005 01:51 PM
Another Drew
07-19-2004 10:02 AM
cvasilik
9
03-20-2003 08:55 PM
