What size (allen) hex head socket to remove axle?
Old 10-13-2005, 09:10 AM
polo92gsr's Avatar
Old 10-13-2005, 09:14 AM
crew219's Avatar
17mm
AudiWorld Expert
Mark P's Avatar
Default no size will fit
(properly) because it is not an allen/hex type. They are triple-squares / 12-point.
I believe it is a 10mm for the B5S4 (and 8mm for the B5A4)
<img src="http://ctny.audiworld.com/mark/s4/clutch/4_remove/dsc01970.jpg">
Old 10-13-2005, 09:15 AM
AudiWorld Expert
Mark P's Avatar
ohhhhh, *that* bolt ;-)
Old 10-13-2005, 09:17 AM
crew219's Avatar
Default you're referring to the bolts that hold the inner cv to the tranny. They're 10mm triple squares
NAPA, Autozone and a few other places carry them
Dave
Old 10-13-2005, 09:20 AM
AudiWorld Expert
Mark P's Avatar
Default which need to be removed to remove those "axles"....
EDIT: I had thought I had removed my half shafts entirely and was thinking I didn't remove that big bolt - but I only removed the inner CV connections.
Old 10-13-2005, 09:21 AM
polo92gsr's Avatar
Default Bolt holding axle to hub?
Thanks for all the replies. I guess I wasn't clear enough but thanks.
Old 10-13-2005, 09:22 AM
AudiWorld Expert
Mark P's Avatar
which axle?
Old 10-13-2005, 09:24 AM
AudiWorld Expert
Mark P's Avatar
Default FYI, the center shaft uses standard allens...
<img src="http://ctny.audiworld.com/mark/s4/clutch/4_remove/dsc01965.jpg">
Old 10-13-2005, 09:26 AM
crew219's Avatar
Default huh? you're losing me. The front axle DOES have a 17mm driveshaft bolt that secures the splines of
the driveshaft the the hub / spindle assembly. The other half of the axle is connected to the transmission by the 10mm triple squares.
Dave
Quick Reply: What size (allen) hex head socket to remove axle?
