removing rear driveshaft
Old 12-23-2004, 05:49 PM
cgerard's Avatar
Default removing rear driveshaft
We have the front subframe disconnected but the driveshaft wont pull out of the tranny. We are tryign to pull the motor forward but it wont budge. am i missing something?
Old 12-23-2004, 05:55 PM
Rest In Peace
Jeff Vader - boscoj's Avatar
Default Sounds like there is some binding, driveshaft should be removed before you lower the subframe
just take a screwdriver and tap it with a hammer on the flange and get it off.
Old 12-23-2004, 06:49 PM
Senior Member
J.Moss@TorqueFactory's Avatar
Did you unbolt it?
Old 12-23-2004, 07:26 PM
cgerard's Avatar
Default we finally got it
I was following simply's guide and it says remove the 6 A bolts which i assume meant allen bolts, but I coudlnt get the shaft to slide out that way for some reason so we removed the six torx bolts at the end of the tranny to get it off.
Engine is finally out of the car, cant say it has been much fun doing this for the first time but I guess learning is part of the learning curve.
Old 12-23-2004, 07:35 PM
cgerard's Avatar
Default car minus the engine
<center><img src="http://pictureposter.audiworld.com/647/dcp_1561.jpg"></center><p>I know it will seem worth it once the k04's are in but I was perfectly happy on K03's. damn the turbo lady!! (might as well damn her three times and thank audi for the first two fixes)
Old 12-23-2004, 07:39 PM
Rest In Peace
Default lookin good . . .
<center><img src="http://66.134.70.69/files/audi/KO4%20Conversion/engine%20removal/124-2440_IMG.JPG"></center><p>
Old 12-23-2004, 07:43 PM
NYC_S's Avatar
Default whats the advantage of pulling the whole subframe if you have the front open as suppose to
the normal engine pull from the front w/o the subframe?
Old 12-23-2004, 07:49 PM
cgerard's Avatar
Default thanks
It is encouraging to see similar pictures. This is by far the biggest automotive undertaking by myself and my brother besides doing a downpipe swap and isntalling springs and struts. I knwo it will all go back together alright but it is still scary to see the whole front of the car laying on the ground.
Old 12-23-2004, 07:50 PM
Rest In Peace
I dunno, you have a smaller piece of equipment laying around? basically the same . . .
Old 12-23-2004, 07:51 PM
AudiWorld Expert
Mirror|rorriM's Avatar
Default Got AIM?
You have a relative with a 355, right?
Quick Reply: removing rear driveshaft
