For those of you who haven't gotten Lemmiwinks to work with a serial emulator,
put the latency timer to 1ms. To do this, plug in your vag-com cable to the usb port you setup to use with lemmiwinks, then open up device manager. Click on ports, and you should see the port that you setup for lemmiwinks. Double click on it, and go to the options tab. Click on the advanced options tab, then put the latency timer to 1ms. This is all from my memory, but it should work.
Specifically, if you get the following error, this procedure should correct it: "ECU uses unknown protocol (KW: 01/8A)"
Thanks to Uwe at Ross-tech for the help!
Gotpancit
02-25-2007 05:33 PM
2000s4biturbo::Uli
12
02-06-2006 06:45 PM
nywidebodys4
06-14-2005 07:30 AM
GoTT83
TT (Mk1) Discussion
11-19-2004 02:51 PM
serp_mage
08-15-2001 05:52 AM
