Removing/cleaning your throttle body on the 1.8T--> FAQ w/pics.
Old 04-14-2002, 06:24 PM
Andy_FL's Avatar
Default Removing/cleaning your throttle body on the 1.8T--> FAQ w/pics.
<b>1. Remove the electrical connector on the top of the throttle body (red shaded area).
2. Remove the cruise control connection (yellow shaded area). There's a small clip holding the ball in the socket; remove the clip, then free the ball from the socket.
<img src="http://images7.fotki.com/v135/photos/4/48510/200021/step1-vi.jpg">
3. Fish out the throttle cable from the plastic housing, as shown by the purple dots.
<img src="http://images7.fotki.com/v136/photos/4/48510/200021/step2-vi.jpg">
4. Remove the four (4) 5mm hex bolts holding the TB to the manifold. You can't see one of them in the picture, but the general position is marked with a green arrow.
<img src="http://images7.fotki.com/v134/photos/4/48510/200021/step3-vi.jpg">
5. Clean it with TB cleaner.
<img src="http://images7.fotki.com/v136/photos/4/48510/200021/step4-vi.jpg">
Before:
<img src="http://images7.fotki.com/v133/photos/4/48510/200021/before-vi.jpg">
After:
<img src="http://images7.fotki.com/v136/photos/4/48510/200021/after-vi.jpg">
6. Put it all back together, using a new gasket if possible.</b>
Did it do much? Not really. It wasn't terribly dirty to start, but I figured I'd rule it out as a possible cause of my dipping idle. Doesn't appear that the 1.8T has an idle air control valve, as found on the 2.8s. Instead, there's this mechanism on the opposite side of the throttle cable, that is no doubt computer controlled to adjust the idle as necessary.
As soon as I opened it up, I closed it :-)
<img src="http://images8.fotki.com/v140/photos/4/48510/200021/dontouch-vi.jpg">
Wheeeeeeeeeeeeeeee.....WOT:
<img src="http://images7.fotki.com/v133/photos/4/48510/200021/wot2-vi.jpg">
That's it. Pretty simple, but I figured I'd put this up as reference if anyone needed to R&amp;R their TB for some reason. Good luck
Andy
Old 04-14-2002, 06:29 PM
Elder Member
BOOSTD's Avatar
LOL "As soon as I opened it up, I closed it"
Old 04-14-2002, 06:36 PM
Andy_FL's Avatar
Default Hehe.
It was just waiting to be broken! Everything looked good and clean, so I closed that biatch up quick!
Andy
Old 04-14-2002, 06:53 PM
Rest In Peace
markbradford's Avatar
Been waiting for this one - thanks Andy!
Old 04-14-2002, 06:57 PM
Andy_FL's Avatar
Default Seriously?
I didn't figure many people would need this, but since I was doing it I figured might as well whip up a little step-by-step. You're approaching a timing belt change, eh? Doing it yourself or taking it to a shop?
Have fun!
Andy
Old 04-14-2002, 06:58 PM
180q's Avatar
Don't forget to do a TBA.
Old 04-14-2002, 07:12 PM
Andy_FL's Avatar
Default Throttle body adjustment?
Yeah I think that took care of itself, when I disconnected the electrical connection to the TB. I noticed when I started it back up that the revs stayed high and took a while to settle down to 8-900rpm. Still did it when I took it for a quick drive. Are those the typical "symptoms"? I think I'll have access to a VAG tool tomorrow, can reset it that way right? Thanks
Andy
Old 04-14-2002, 07:17 PM
180q's Avatar
Default Re: Throttle body adjustment?
Yeah, the best way is with the VAG I believe, just like pulling the ecu I guess..
Chad
"sig-less"
Old 04-14-2002, 07:22 PM
Andy_FL's Avatar
Default K. Will try it tomorrow.
Thanks.
Andy
Old 04-14-2002, 07:34 PM
Rest In Peace
Default Ya I never really looked at the hardware, but intended to do it.........
along with the fuel filter.
Ya- Motopersona is doing my Timing Belt and EFK, and perhaps a few other small things such as the fuel filter.
Quick Reply: Removing/cleaning your throttle body on the 1.8T--> FAQ w/pics.
