72 Climate control tricks in very bad english (from alt.autos.audi)
From http://www.tt-owners-club.de/tips/tips-faq2.htm
If one has an air conditioning system in its TT (or another Audi), one
can recall additional operating parameters of its auto. One presses
thereby the " circulating air switch " and the switch for " nozzle " at
the same time above. One has then the selection of 78 control-learns
(C), which one over the temperature regulator keys (+/) to head for can.
After selection one must press the circulating air key again.
1.System error
2.Actual value feeler virtually
3.Actual value interior feeler console
4.Actual value outside temperature - feeler wasserkasten
5.Actual value outside temperature - feeler bumper
6.Actual value blowing out feeler floor space
7.Actual value blowing out feeler Mannanstroemer
8.Display CHECK 9.Actual digital value answering potentiometer
temperature flap 10.Debit digital value temperature flap 11.Actual
digital value answering potentiometer A/C flap 12.Debit digital value
A/C flap 13.Actual digital value answering potentiometer Fuss/Def flap
14.Debit digital value Fuss/Def flap 15.Actual digital value answering
potentiometer ram air flap
16.Debit digital value ram air flap
17.Driving speed (km/h)
18.Actual value of the blower voltage (volt)
19.Desired value of the blower voltage (volt)
20.Actual value of the compressor/on-board voltage (volt)
21.Number of low-voltage events (not volatile)
22.Sound status of the high pressure switch
23.Number of high pressure events (volatile)
24.Number of high pressure events (not volatile)
25.A/D value kickdown switch
26.A/D value hot light
27.Engine speed
28.Compressor number of revolutions
29.Coding
30.Software-Version
31.Software index
32.Potentiometer error counter temperature flap
33.Potentiometer error counter A/C flap
34.Potentiometer error counter Fuss/Def flap
35.Potentiometer error counter ram air flap
36.Temperature flap impact cold
37.Temperature flap impact warm
38.A/C flap impact closed
39.A/C flap impact opened
40.Fuss/Def flap impact Def
41.Fuss/Def flap impact foot
42.Ram air flap impact up
43.Ram air flap impact too
44.Operating cycle counter
45.Interior temperature counted (Ninc) dig
46.Outside temperature filtered (°C)
47.Outside temperature not filtered (°C)
48.ECOR
49.Coolant temperature
50.Service life in min
51.Engine temperature °C
52.Compressor Abschall conditions (see appendix) 53.Display more
actively el. Outputs: Compressor / circulating air valve /
water valve
54.Rule code digit
55.Outside temperature °C
56.Interior feeler virtually °C
57.Interior feeler console °C
58.Temperature wasserkasten °C
59.Temperature bumper °C
60.Blowing out feeler floor space °C
61.Blowing out feeler Mannanstroemer °C
62.Sun intensity W/m-1
63.Sun intensity filtered W/m-1
64.Delta exhaust rise
65.Delta A/C Klappenverschiebung
66.Time constant / 1.6 seconds
67.Cold weather starting correction
68.Max. correcting variable for i and sectionsection section
69.Actual value blowing out feeler foot (cnts)
70.Desired value blowing out feeler foot (cnts)
71.Deviation (Epsilon)
72.Proportion (+ heat / - cool)
1.System error
27.Engine speed
29.Coding
30.Software-Version
31.Software index
48.ECOR
water valve
54.Rule code digit
goliath1
S6 (C7 Platform) Discussion
02-21-2015 09:24 AM
kindkind
01-16-2008 10:08 PM
