Go Back   AudiWorld Forums > Audi Models > Audi A4 > A4 (B5 Platform) Discussion
Old 09-28-2001, 12:39 PM   #1
hellboy
Account #: 12901
Default What causes tires to cup, and what's the best way to prevent this?? TIA
hellboy is offline   Reply With Quote
Old 09-28-2001, 12:41 PM   #2
EdP
AudiWorld Uber User
Account #: 2465
Default here...
EdP is offline   Reply With Quote
Old 09-28-2001, 12:43 PM   #3
hellboy
Account #: 12901
Default Thank you sir.
Old 09-28-2001, 12:47 PM   #4
nick n
Account #: 126
Default In addition you should..
only push down on the inside of the car, meaning, pop the hood a push over the shock tower. The same goes for the rear.
nick n is offline   Reply With Quote
Old 09-28-2001, 12:47 PM   #5
Silver Streakin'
Member
Account #: 10901
Default sounds like worn out shocks to me...
Cupping is a condition caused by the tire bouncing as it rolls. Small areas of heavy wear are created. Worn shocks are often the cause of cupping, but loose suspension parts or tire imbalance are also possible causes.
-Jeff
2001.5 A4 1.8TQMSCC with APR SIII, EVO FMIC, Stoptech-less, STaSIS Tracksports 600F/750R
ACNA MidOhio video
Montreal race school and PDA Pocono video
Silver Streakin' is offline   Reply With Quote
Old 09-28-2001, 12:48 PM   #6
hellboy
Account #: 12901
Default Thanks for the info guys.
Old 09-28-2001, 12:49 PM   #7
Evan (Vogon)
Account #: 17150
Default I don't have cupping, but I have this...
dealer says I drive too hard...
My Current project I'd like to show off:
Chemistry Web Site
Audi TT 225QM Roadster Black/Baseball
Evan (Vogon) is offline   Reply With Quote
Old 09-28-2001, 01:06 PM   #8
The Blizzard of Oz
Account #: 25846
Default If they are Pirelli, they do it automatically
It's the nature of the beast. Otherwise, bad shocks.
The Blizzard of Oz is offline   Reply With Quote
Old 09-28-2001, 03:35 PM   #9
Tbandido
Junior Member
Account #: 23488
Default Another option is to make sure no run-out problems exist...
I had a tire problem that caused cupping, not as deep as with bad shocks though. A "good" tire shop can do a load variance balance test to make sure the high spot on the wheel matches the with the low spot on the tire. Sounds confusing, but a perfectly balanced tire my not be rolling round. At high speeds, in my case only 50mph, I would get a slight vibration, not bad, but bad enough to cause cupping on the front tires.
After I had the shop fix the problem, they remounted the tire on a different location on the wheel, it was AMAZINGLY different. It felt like a different car. I had not realized that it was this bad before.
Note, I had my tires balanced 2 times before that, by a different shop and each time they said they were fine.
Anyway, my 2 cents. Good Luck
Tbandido is offline   Reply With Quote
auto, car, causing, cup, cupp, cupping, front, inside, long, prevent, thread, tire, tires, what, whats
Forum Jump
