Go Back   AudiWorld Forums > Community Discussion > Off-topic Discussion
Old 10-19-2006, 02:54 PM   #1
Dustin A4
Account #: 27909
Default The shift lock on an Automatic Jetta won't let the car out of park (yes the brake is pressed).
<center><img src="http://static.worldnow.com/nctd/images/cars/02jetta-4.jpg"></center><p>
Where is the manual override to release the shift lock on a Jetta?
Dustin A4 is offline   Reply With Quote
Old 10-19-2006, 02:56 PM   #2
im_cecil
Account #: 30439
Default Was it parked on a hill? The torque converter could be locked up -- if so you need someone
to push the car in the opposite load direction to take the strain off.
im_cecil is offline   Reply With Quote
Old 10-19-2006, 02:57 PM   #3
wagongotya
Account #: 90994
Default the brake pedal switch/sensor might be loose or disconnected. try putting it in neutral before
you start it, that's what I had to do with my old car when that happened. The switch tells the computer that you have the brake depressed and can shift the car out of park
|sig|
EPL Custom Tune w/ OEM RS6 Turbos.
"I wish I could have a stage 3 car to be disapointed in. :-)" - IBG 2007-01-16 16:15:26
RIP O.W. Kenobi
|/sig|
wagongotya is offline   Reply With Quote
Old 10-19-2006, 02:59 PM   #4
Dustin A4
Account #: 27909
Default Tried that, but it won't let the car into D or R. Every time you restart the car it locks.
Old 10-19-2006, 02:59 PM   #5
Baraqyal
Elder Member
Account #: 70341
Default Maybe a problem with the ignition?
Baraqyal is offline   Reply With Quote
Old 10-19-2006, 03:00 PM   #6
washparkS4
Account #: 80383
Default Did you check the ignition switch?
Speed doesn't kill... its the sudden stop that kills.
washparkS4 is offline   Reply With Quote
Old 10-19-2006, 03:00 PM   #7
Dustin A4
Account #: 27909
Default I am 90% sure pedal switch/sensor... is there a manual override to get it moving?
That way he can drive to the dealership and get it fixed. Otherwise it needs to be towed.
More $$$ (out of warr)
Old 10-19-2006, 03:01 PM   #8
wagongotya
Account #: 90994
Default srsly, check the switch on the brake pedal (up at the top of the pedal arm)
|sig|
RIP O.W. Kenobi
|/sig|
Old 10-19-2006, 03:02 PM   #9
Dustin A4
Account #: 27909
Default Starts, stops, runs fine, and the wheel turns. I think it's the sensor on the brake.
Old 10-19-2006, 03:03 PM   #10
Dustin A4
Account #: 27909
Default If the switch is broke it will need replaced. Looking for a temp workaround to drive it.
2000, 2001, 2007, 2008, a4, automatic, brake, control, jetta, lock, manual, override, park, problems, release, shift, volkswagen
HTML code is Off
Forum Jump
