Audi B5A4 1.8T Transmission Multifunction Switch Replacement Writeup
the gauge cluster that show the gears, p,r,n,d,4,3,2 doesn't show up when i switch gears. every gear works fine but when in reverse it acts as if it s in neutral it just revs when you give it gas. i have never worked on a Audi but it seems to be the multi function switch... wo i be correct with this guess???
MFS
Well after careful scrutiny, I am now convinced that the MFS is in need of attention.
The TCM that I put in seems to work fine. But when I shift into R(everse) N(eutral) shows up on the instrument panel.
All of the others register just fine.
With any luck, some contact cleaner will do the job and save the girl $$$.
I have read Nates write up many times.
How did you make out with your repairs?
GOING FORWARD!
WHO NEEDS REVERSE ANYWAY?
GOING FORWARD!
GOING FORWARD!
GOING FORWARD!
The other thing to do if you are brave and the car drives is loosen the wheel bolts a couple of turns but don't remove them. Then drive around the block slowly turning back and fro. That seem to loosen them up. Only for the brave but it works!
#18
Wheel
I got the wheel off, eventually. Ended up using some 4 by 4's and a hydraulic jack to pop the little puppy using the opposite wheel for leverage.
That is the good news.
Nates picture looked just like this car, unfortunately, the cleaner didn't do the trick.
Well, off to find a MFS.
The price difference between the later models, although they look the same, and the 96 models is significant.
Are they interchangeable?
As ususl, thanks for the support.
#19
MFS Switch replacement
Ok I removed the two bolts on the bottom of the transmission mount with the 13mm socket driver. Then the 17mm nut to removel the center bolt.
This is where I am.
Kinda lost here.
What do I do next?
This is where I am.
Kinda lost here.
What do I do next?
#20
You need to take the transmission mount completely off..thats what I did for mine...You will remove that bolt to take the mount off. Once you do that, you will see the bracket that covers the MFS)..as shown in the Nate's pictures.....Take that bracket off
