1st to 2nd gear thump
Old 01-07-2014, 05:14 PM
  #21
2k6blacka8's Avatar
Originally Posted by TSHong
I also forgot that I also did a throttle adaptation with no change back then too.
So how did you go about doing the throttle adaptation??
Old 01-07-2014, 06:27 PM
  #22
TSHong's Avatar
Using VCDS and Snap On tool. I had read that could effect it but made no difference.
Old 01-07-2014, 06:31 PM
  #23
2k6blacka8's Avatar
Oh ok. Yea I don't want to get into adjusting stuff and not know what I'm doing lol.
Old 01-07-2014, 07:32 PM
  #24
mishar's Avatar
Well at least I know updating to the blue fluid would lighten my wallet quite a bit. I don't want to spend money one something that probably won't help.
You don't have to change ATF in order to update software. I can't find PDF file about hooting and ATF flush to the blue, but MP has it. It includes adaptation instructions.
Old 01-07-2014, 07:53 PM
  #25
2k6blacka8's Avatar
Oh ok. I thought when you change to the blue fluid you have to update it. Well I guess it doesn't hurt to try to update it on the current fluid. Heck i'll ask the dealer tomorrow about the fluid change TSB and see what they say. Thank you Misha. I hope they don't charge me a lot doing it.
Old 01-07-2014, 08:10 PM
  #26
mishar's Avatar
Found it.
File Type: pdf
Old 01-07-2014, 08:13 PM
  #27
mishar's Avatar
Try first adaptation yourself as TSHong did. It is described in PDF attached.
Old 01-07-2014, 08:56 PM
  #28
2k6blacka8's Avatar
OMG Misha you are the man. Thank you very much. I'm for sure going to try this and with my fingers crossed this should work. TSHONG didn't do this procedure. He kept driving it and it got better as time on and it finally adapted itself. With the low mileage 77k I have I don't see a whole lot of wear in this gearbox. Plus I just recently put in a new battery. This will help a lot. I'm not going to spend money again on a service because it was done 14K miles ago. I'll see what the dealer will do and if they don't do anything then this is what I will do.
Old 01-08-2014, 03:03 AM
  #29
TSHong's Avatar
OMG Misha you are the man. Thank you very much. TSHONG didn't do this procedure. He kept driving it and it got better as time on and it finally adapted itself.
I tried but this adaptation did not work for me. It got better on it's own.
Old 01-09-2014, 01:18 PM
  #30
2k6blacka8's Avatar
Update, I just got a call back from the dealer and they did the adaptation drive procedure and no change. I got a feeling me driving it wont be any better. Now they want to do the blue fluid update and the cost for that is 1255.84 plus tax. I have some decsions to make. What do you think I should do? Should I chance it and put the money in it or just say screw it? Another step after that is to change the megatronics unit which is part of the valve body and That will cost 4000 plus tax and that's if that fluid change and update doesn't work. Opinions would be greatly appreciated. Thank you very much in advance.
Quick Reply: 1st to 2nd gear thump
