Intake backfires...
Old 01-16-2004, 03:58 AM
mint875000cstq's Avatar
Default Intake backfires...
I get intake backfiring when cold at startup and on acceleration or if I just sit and ram the throttle quickly/repeatedly. What should I be looking for? Ignition? Fuel supply? Air Temp Sensor? Air Filter? Fuel pump is about a year old and fuel filter maybe 6 mo. New O2sensor, new headerpipe/cat. Dist bearings are bad. Thanks , this forum rules!!
-Aaron 1987 5000CSQT 271,000 miles
Old 01-16-2004, 04:45 AM
rooster 2's Avatar
Default I think that you could have a bad engine valve.......
doing a compression test might pinpoint which cylinder is the problem. You might also want to check to see if the timing is correct...............Rooster
Old 01-16-2004, 06:50 AM
cuatrokoop's Avatar
Default Make sure it is actually backfiring up into the intake.
The 5kq (non-turbo), with a partially bad exhaust system, would backfire when doing the same thing (playing with the throttle). I agree, check the timing too.
Old 01-16-2004, 07:47 AM
audiqv8's Avatar
Default Re: Make sure it is actually backfiring up into the intake.
Check for a crack exhaust manifold or leakage in your exhaust system. Outside air is mixing with unburnt gas. Also check to see if all plugs are firing. Backfiring is caused by unburnt gas entering the exhaust system and the heat from the cat and or muffler is causing the unburnt gas to explode.
Old 01-16-2004, 07:52 AM
cuatrokoop's Avatar
Or just excessive back pressure can cause hiccups...That was my problem.
Old 01-16-2004, 08:52 AM
Doesnt the computer on the 5000 turbo automatically regulate the timing? I thought that once the dist. was adjusted close to center that the ECU took over...I would also need to mention that my dist howls very loud when cold (previous post) could a bad dist. shaft cause timing problems? This car is getting too old! I wish I was an Audi Mech.!!! :-D I love this old car!
Old 01-16-2004, 08:58 AM
Default I should also mention.......
I have exhaust manifold leaks (I pretty sure broken studs and my Head gasket seeps oil...Part of the problem?????
-Aaron
Old 01-16-2004, 03:48 PM
rooster 2's Avatar
Default Yea, part of the problem..........
I had that problem. When, I finally had the manifold studs replaced, the head had to be pulled. That's when the mechanic found burned exhaust valves caused by the exhaust leak at the manifold. I should have had the broken studs replaced sooner before it ruined the exhaust valves. I gotta think you are having the same problem. Sorry, but it isn't cheap or easy to repair. ........Rooster
Old 01-19-2004, 04:32 PM
Jon Clay's Avatar
Default Finally someone with the same problem as me....
by the way, sorry to hear that you have it too...
I haven't figured it out, but I think it's got to be related to the fuel distributor. Mine also makes a lot of noise and I've inquired about a rebuild kit for it. Aparently there is one, but I'd rather drive it as is til I can afford to go EFI. I'm hoping that will fix every problem with my car, as I am a believer that CIS is a virus which infects various systems of the car.
Do you think that the "backfire" may be related to the air metering plate being stuck and then popping open? I've wondered about this...
Good luck
Jon
A4Driver
07-14-2008 06:43 PM
deephouse
Audi Original "S" Cars
01-09-2008 09:10 AM
holychild666
04-30-2003 12:03 PM
NYLawyer
02-26-2002 11:53 AM
dcrall
10-14-2001 01:37 PM
Quick Reply: Intake backfires...
