AAH rebuild parts
AAH rebuild parts
Anyone know a good place to order parts to rebuild the motor completely? Pistons, rings bearings... I've been lookin but can't find anything.
Got all my stuff from Pelican parts. Are you looking ti upgrade your pistons for a different compression? If not than there's no reason to replace then unless they gauge out of round. Pretty expensive too.
If so, JE pistons.
If so, JE pistons.
I don't know yet. I haven't torn into my motor yet. I've got 355,000 miles on it. I don't know if ill have to bore it put or not. I just want to make sure all parts are available before I start. We're you happy with the quality of parts from pelican?
Oh yeah. Most of their stuff is oem. When you get it apart the heads should be resurfaced and cleaned by a machined shop. They'll also check the valve guides and install new seals. You will also want to gauge the cylinder walls about 1 in from the top and bottom and the pistons. That will tell you everything you need to know. Don't take block measurments with the block on a stand.
Plasti-gauge all bearings. If you do tear it open, i can give you every tolerance. Definitely want new rings and to hone/deglaze your cylinder walls.
dorn man, i wish i was that lucky :-)
cams: http://www.eurospecsport.com/product.../camshafts.htm
i get about 19mpg in town and about 25-26 on highway. i sued to be able to get 30-32, but something changed and the MPG's started sucking, no idea what :-(
top end was rebuilt, heads ported on the intake side. vaps velocity staked airbox, converted MAS with post delete. ill try replacing the cats sometime soon, maybe that will help :-S i know they rattle
