Tired of throwing money at my Car. Please Help.
Old 05-25-2012, 10:25 AM
cjromney's Avatar
Originally Posted by upallnight
You could have a bad fuel pressure regulator. The diaphram could be torn and the vacuum line that operates the fuel pressure regulator could be sucking additional gas into the intake manifold. Pull the vacuum line from the fuel pressure regulator and see if it is wet with fuel, it should be dry. If it is wet that is your problem.
Decided to check that out yesterday. The lines were dry. Don't think that's it. I also found that it doesn't make a difference if I allow a vacuum leak to the manifold. The leak has to be upstream between the MAF and the Throttle Body. As a temporary fix I have rigged a crankcase breather filter to the intake duct to allow a leak with filtered air. The idle problem has gone away but the check engine light still comes on. I'm waiting for the Ross-Tech VAG-Com to read the codes.
Old 05-25-2012, 05:44 PM
Prospeeder's Avatar
did you have the car running when you checked the regulator? fuel does evaporate quickly.
Old 05-28-2012, 10:40 AM
cjromney's Avatar
Yeah
Old 06-01-2012, 01:44 PM
CRAZY_RUSSIAN's Avatar
ive never hear of fuel pressure regulator going out on these cars.
have you cleaned the contacts on everything? also test your temp sensors (there are 2 of them)
Old 06-02-2012, 07:31 PM
upallnight's Avatar
You must not read all the forums.
https://www.audiworld.com/forums/sho....php?t=2821343
Old 06-05-2012, 12:28 PM
your right, i dont read all of them and im not here all that much anymore
Old 08-10-2012, 06:37 PM
jbasilio95b4's Avatar
so what happen with your car because my car pulled up the same codes and the light comes on only after i drive 10-12 miles and about 1 mile on the way back from work.
Old 08-14-2012, 02:49 PM
  #18
cjromney's Avatar
I'm still not sure. I haven't figured it out yet. Mine is the same with the engine light not coming on till later in the mornings. I have found that it is worse with warmer temperatures. I will let you know if i figure anything new out. Please do the same if you figure it out.
Old 08-15-2012, 08:43 PM
  #19
yea, I believe that it has something to do with the temperature because its been cool out and it hasn't come back in the last 2 days but i think the hose that goes into intake manifold from the brake booster causes a vacuum leak due to cracked rubber. I tight mine down with a clamp but I am going to replace soon. I havent had time to try this but it may help you if you do,
https://www.audiworld.com/tech/eng62.shtml
Old 12-26-2013, 12:19 PM
  #20
cjromney's Avatar
Default Fixed
After all this time of fiddling, searching, and much determined contemplation, I have the solution. All of the idling issues were caused by my car running very rich. It was running rich because of issues with the engine coolant temp sensor and the ground wire on the back of the intake manifold being loose. Thanks for the help and I hope this helps others. It has been very frustrating.
eurban
A4 (B8 Platform) Discussion
11
03-14-2015 03:21 PM
MIKOSB5
07-25-2006 07:19 AM
ignazzio
01-28-2006 10:13 PM
SuperGreg
12-04-2003 10:54 AM
Quick Reply: Tired of throwing money at my Car. Please Help.
