HELP! Upright wipers! 04 A4
Old 03-03-2010, 12:53 PM
algophobia's Avatar
Default HELP! Upright wipers! 04 A4
During my commute to work today I went to used my wiper and when it stopped it stopped short on the window a couple inches from all the way down. That bothered me so I clicked the single swipe and it stopped another inch or two up higher from the last swipe.. and so on ratcheting itself higher and higher. I figured what goes up must come down so since it was verticle I tried again and again to see if it would start going back down. It didnt. Now my wiper is stuck upright on my window (in hindsight 2 inches from bottom isn't looking so bad). Anyone have any ideas what the problem is and how to fix it? the wipers work fine, they just stop upright instead of at the bottom when they are not in use.
Thanks,
John
Old 03-03-2010, 01:13 PM
naconi's Avatar
https://www.audiworld.com/forums/sho....php?t=2384763
Old 03-03-2010, 02:24 PM
algophobia's Avatar
I saw that forum, but the person with the same problem never said if that fixed anything and the posts following his are all about if the wipers are "slow" or "sticking". Mine work fine they just start and stop at verticle instead or horizontal. Are you saying I should buy a new bracket assuming thats whats wrong?
Old 03-03-2010, 04:42 PM
algophobia's Avatar
Its okay, I found out from a german mechanic that it is the window wiper transmission that went bad. I will confirm this when it is replaced and the problem no longer exists.
Thanks for always helping though
Old 03-03-2010, 05:34 PM
naconi's Avatar
In that thread there is a link to this thread,
http://www.audizine.com/forum/showth...eshield...help!
and post #9 in that thread it shows you what to adjust. It says if they are working fine but stopping in the wrong position it is not the motor.
Old 03-03-2010, 07:12 PM
algophobia's Avatar
Thanks. Do you know what position the "home" position should be when I try adjusting that?
Old 03-04-2010, 12:24 PM
naconi's Avatar
No, sorry I have never done that.
Old 03-07-2010, 04:26 PM
Roch_Ultrasport's Avatar
From Service Manual. See attached pic.
Windshield Wiper Blade Park Position, Adjusting Procedure
– Switch on ignition.
– Actuate touch-wipe function and allow wiper motor to move to end position.
– Switch off ignition.
– Position wiper blades on windshield and align as follows:
Dimension -a- = 24 mm.
Dimension -b- = 44 mm.
Note
The figures given here are the distances between wiper blades and cowl panel grille of plenum chamber at bottom edge of windshield.
– Tighten nuts for wiper arms.
– If necessary, re-align wiper arms and tighten nuts again.
Tightening Specifications
Component - fastener Nm
Wiper arm - nut 21
Old 03-07-2010, 05:19 PM
algophobia's Avatar
Thank you very much! I will hopefully have daylight one day this week when I am done work and can fix this issue by the weekend. Thanks naconi and roch ultrasport for all your help, it is greatly appreciated!
Old 03-07-2010, 06:08 PM
Your welcome. I used this procedure when I had to repair mine because of the common problem of the linkage becoming stuck.
You should be able to pick up a tool for removing the wiper arm (see attachment) for around $10.00 at any parts store.
Quick Reply: HELP! Upright wipers! 04 A4
