12v turbo rebuild and install
I finally have been able to start re-installing my engine. It's been slightly over two months since I removed it for a complete rebuild. Hopefully it will be up and running by Sunday.
Here are the specs
JE 8.5:1 .020" pistons
stock rods
balanced internals
raceware headstuds
arp rod bolts
port and polished head
shimmed valvesprings
2.7tt headgaskets
tdl unequal length headers
upgraded clutch
there's more I just can't remember it all
should be good for around 450HP @ 18psi.
Here are some various pics of the install and parts
<img src="http://pictureposter.audiworld.com/620/no_engine.jpg">
<img src="http://pictureposter.audiworld.com/620/front_engine.jpg">
Here is the 60-2 wheel, and magentic sensor and bracket required for the crank position for the Tec-II. The pic is fuzzy, but it is the only one I have.
<img src="http://pictureposter.audiworld.com/620/60-2sensor.jpg">
You can see on the intake manifold the low-impedance 550cc injectors, fuel pressure sensor, and 3bar fuel pressure regulator from a 1.8t replacing the stock 4bar one.
<img src="http://pictureposter.audiworld.com/620/im.jpg">
The first set of TDL headers for the B4 12v
<img src="http://pictureposter.audiworld.com/620/headers.jpg">
Intercooler
<img src="http://pictureposter.audiworld.com/620/intercooler.jpg">
Clutch
<img src="http://pictureposter.audiworld.com/620/clutch.jpg">
Here is the piping joining the exhaust manifolds together prior to the turbo. You can see the flanges that need to be welded on to fit the headers.
<img src="http://pictureposter.audiworld.com/620/uppipes.jpg">
Finally the turbo and downpipe T3/T04E .63a/r, the boost control solenoid, oil pressure sender and 02 sensor can all be seen.
<img src="http://pictureposter.audiworld.com/620/turbo.1.jpg">
Here are the specs
stock rods
balanced internals
raceware headstuds
arp rod bolts
2.7tt headgaskets
upgraded clutch
Intercooler
Clutch
Re: 12v turbo rebuild and install
Electromotive TEC-II in parallel with stock ecu.
Here is the write up I did on the install a few months ago
<a href="https://forums.audiworld.com/performance/msgs/30798.phtml" target="_top">https://forums.audiworld.com/performance/msgs/30798.phtml</a><ul><li><a href="https://forums.audiworld.com/performance/msgs/30792.phtml">https://forums.audiworld.com/performance/msgs/30792.phtml</a</li></ul>
Very Cool Rob. Let us know how it goes...
I'll be doing the same thing (minus the turbos and Tec-II) by the end of the year. I think the pistons just arrived and TDL is working ont the engine as we speak.
I guess the next step for me will be to go for the TEC-II. Hope you won't mind lots of stupid questions...
Scott
Scott
Re: Also, did you have the engine bored out to 2.86?
I went .020" overbore with the pistons which gives an actual displacement of slightly over 2.80 liters. No worries about strength with such a minimal change in cylinder wall thickness. I went with .020 over simply as a matter of convenience. Also, any bigger and I wouldn't have been able to run the 2.7tt HG.
