What does the esp button do?
Old 08-19-2002, 09:41 AM
Scott Evil's Avatar
Wow, I just thought it helped the car read my mind.
Old 08-19-2002, 09:46 AM
Senior Member
Kent L's Avatar
Default According to the Bentley manual, it'll turn itself on if the brake pedal is depressed...
Then off again once you are off the brakes. It should stay off if you are just on the gas.
Old 08-19-2002, 09:47 AM
Member
KOpork's Avatar
Default It basically helps when the car feels like its losing control like into a turn you are going to hot
into. Snow is a different situation altogether.
Old 08-19-2002, 09:58 AM
hman_a4's Avatar
Default here ... read this:
<ul><li><a href="http://www.vwvortex.com/news/02_00/02_11_00/index.html">Click for ESP info...</a></li></ul>
Old 08-19-2002, 10:24 AM
Elder Member
George @ BostonAudi's Avatar
Default Yeah, its got a nice habit of doing that at the limits of adhesion...
And thereby sending your car off the road/track.
One of the worst designed things on the car. Its great if you're putzing around town in the rain or snow, but its horrible if you are really pushing the car. Dangerous, in fact.
gk1
gk1's Avatar
Default Isn't EBD basically electronic brake bias, and EDL is for transferring power side-to-side?
I thought EBD is designed for redistributing brake load front-rear in the event the car is heavily loaded or under heavy braking situations so the brake distribution is even. Where EDL (Electronic Differential Lock) Also working with the brakes and ABS sensors is for side-to-side power transfer.
Old 08-19-2002, 12:03 PM
Senior Member
Auto Union Jack's Avatar
Give you the impression that you can actually turn off the driver aid.
Old 08-19-2002, 12:27 PM
  #18
bluebird's Avatar
thanks
Old 08-19-2002, 01:34 PM
  #19
quattroinAK's Avatar
go out in the rain and drop the clutch with it on...then with it off...now you know!
Old 08-19-2002, 01:38 PM
  #20
Default i drive in the snow for nearly 8 mos. a year and mine has never "come back on" it most deffinately
will let you go out of control if you turn it off. i know because i have.
Quick Reply: What does the esp button do?
