HELP! Upright wipers! 04 A4
Old 04-20-2014, 11:24 AM
  #11
mwmkmwmk's Avatar
Originally Posted by algophobia
Thank you very much! I will hopefully have daylight one day this week when I am done work and can fix this issue by the weekend. Thanks naconi and roch ultrasport for all your help, it is greatly appreciated!
In post #9, the graphic does not open on my Mac. (I know this is an old post, but this just happened to my 2004 Audi A4). Without the graphic/picture, I do not know what bolt to loosen to move the wipers back to "home" position. Thanks for your help.
Old 04-20-2014, 12:21 PM
  #12
Roch_Ultrasport's Avatar
If your talking about just moving the wiper arm itself there's a nut at the bottom of each wiper arm, under the cap, that needs to be loosened.
Old 04-21-2014, 04:09 AM
  #13
mwmkmwmk's Avatar
Default Wipers upright
Sorry, wasn't referring to wiper arm nut, but the nut that I should loosen so that I can move both wiper arms, and the linkage, back to "home" position so the wipers are not upright at rest.
Old 04-21-2014, 06:47 AM
  #14
I've attached the workshop procedure from ElsaWin (in PDF format) for the Windshield Wiper systems on a A4.
There is a mounting point for the motor that the wiper arm linkage attaches to. You adjust the wiper arm position by adjusting that mount point.
You will need to remove the nut holding the wiper linkage to the motor. Then pop the linkage arms up off the mounting point. Rotate that mount point to the correct position then re-attach the linkage arms an nut.
You could conceivably just pop the arms off and place them back on in the right position but if that lever used at the motor is off then the wipers will always be off.
There are some pretty good write-ups from days gone past on this board and over on Audiworld.com showing how it's done with pics. Maybe the pics are no longer there. See if you can use google maybe for that site and grab a cached version.
File Type: pdf
Old 04-21-2014, 07:05 AM
  #15
mwmkmwmk's Avatar
Thanks for the quick response. I'll attempt and update you on the result.
Old 04-21-2014, 09:53 AM
  #16
mwmkmwmk's Avatar
Default Upright Wipers
Thanks for your help. Done!
Old 04-21-2014, 12:17 PM
  #17
Glad 2 b of service.
Sprinkz
06-06-2011 06:20 PM
audi1121
6
01-19-2009 07:58 PM
momotoTTe
08-15-2004 04:38 AM
momotoTTe
10
12-01-2002 12:37 PM
El_Exigente
03-20-2002 12:02 PM
Quick Reply: HELP! Upright wipers! 04 A4
