ECON function wont shut off (No AC)
Old 04-13-2014, 01:15 AM
10speed's Avatar
Default ECON function wont shut off (No AC)
Does anyone know if a bad ambient air temp sensor could cause AC system shutdown?
Old 04-14-2014, 04:24 AM
lyleswk's Avatar
That's usually a sign of low Freon.
Old 04-14-2014, 04:33 AM
uberwgn's Avatar
^^Yes.
Old 04-25-2014, 08:16 AM
Witt_4rings's Avatar
So low free - on would cause the ECON button to stay on? I have this problem as well.
Old 04-28-2014, 04:24 AM
lyleswk's Avatar
Yes. It is a self protect feature to prevent the compressor from running out of the lubricant which is mixed with the Freon. Have a reputable A/C shop check the high and low side pressures.
Old 05-01-2014, 03:51 PM
I added freon myself but now when I turn car off it sounds like a jet engine powering down just not as loud obviously. Do you think I overcharged it? Or is this normal? Says 510 grams holding capacity I put about 2-300 get in.
Old 05-02-2014, 04:11 AM
lyleswk's Avatar
No way of really telling without putting pressure gages on it.
Old 05-05-2014, 12:13 PM
Most def thanks.
Old 04-19-2019, 12:03 PM
adamhschmidt's Avatar
@Witt_4rings, my car is having the same issue right now preventing me from passing smog. The ECON light stays on, my engine is super loud and when I turn it off, it sounds like a jet is shutting down (like you said, not as loud though). Did you end up figuring out the problem? it seems like our problems are/were pretty similar, any help would be greatly appreciated.
Old 04-19-2019, 02:40 PM
JJm64123's Avatar
do these audis have to be filled with a certain freon and oil lubricant? I can't just charge the system with regular freon i can get from an auto parts store? Previous owner disconnected lines after a front end accident and never recharged everything.
Quick Reply: ECON function wont shut off (No AC)
