TPMS & Brake Pad Warning with Spare Tire
Old 01-19-2014, 09:44 AM
Costasz's Avatar
Default Thanks, I don't see anything ripped
Originally Posted by LLskier23
I hit a pothole in my old Allroad one time and the wheel travel was jarring enough to rip the pad sensor wire from its connector. Check the front pads on the side you hit and make sure the pad sensor wires are all intact and securely connected. I just had to splice mine back together and everything was resolved.
I have a VAGCOM so I ran it. It's not showing any brake related faults. How can the light in the dash be on but VAGCOM not picking up any errors?
Old 01-19-2014, 05:51 PM
LLskier23's Avatar
Not sure if that would trigger an error in VCDS. It's technically just a warning light just like the low washer fluid is. I bet if you ran a scan with no washer fluid you wouldn't get an error either.
Old 03-28-2014, 02:03 PM
Costasz's Avatar
Default A couple more things that started happening to the car shortly after
The adaptive headlight warning came on (both headlights work though)
and the there's a check engine light. VCDS says it has to do with air flow measurement. Probably the MAFs need cleaning.
ebod0000
A6 (C7 Platform) Discussion
170
06-07-2018 01:39 PM
rsixxer23
01-06-2016 03:25 AM
audio_video_guy
Q5/SQ5 MKI (8R) Discussion
15
09-09-2015 10:22 AM
ECS Tuning-Audi
09-02-2015 11:39 AM
C6Silver
Q7 MK 1 Discussion
09-01-2015 08:46 PM
Quick Reply: TPMS & Brake Pad Warning with Spare Tire
