Do HIDs lose brightness over time?
McGyver meets Hardware store Kingpin!
Well done! (Tips cap) It's nice when you find a use for old hardware like that. That's why the old lady has no defense to my hoarding of snap rings, cotter pins, zip ties, crosby clamps, xena posters, and famous golfers chew cups. You know, the usual stuff. I am using your post as evidentiary support in next "discussion" over garage storage requirements vs 2nd remodeling of kitchen.
http://www.audizine.com/forum/showth...lft-headlights
As to the original question, most HID bulbs have an effective lifespan of about 2000hrs. Since they do colour shift as they age, they should always be replaced as a pair.
Audiworld Senior Member
That probably would have been me . The projectors are the EvoX-R and they are a direct bolt in replacement for all facelift C5's. With some fabrication they have been swapped into AllRoad lights as well so I assume the process would be similar for the pre-facelift C5 too.
Unless someone modified your lights before you bought yr car they're likely still fresnel lenses. You have to look closely, but you will see concentric lines in the lense if they're OEM. The yellow/brown border you're referring to is caused by diffraction at the edge the cutoff shield edge being modified by the OEM fresnel lenses. It's the same phenomenon that produces the blue colour band on the EvoX's, the colour is stronger because the clear lenses produce less diffusion in the beam. I didn't buy new bulbs to go with the new projectors, both the before and after photos in that thread at using a set Phillips 85122+ that I bought a little over 3 years ago. At the time those pics were taken I'd guestimate they had about 600 - 800 hrs of total use.
Edit: FYI, your C5 headlights are bi-xenon as well. All A6's with the xenon option use a combination iof halogen and xenon for high beam. "Bi-xenon" just refers to the fact that the projectors cutoff shield is actuated to allow them to flip out of the beam on high and therefore expand the output. Just try replacing the bulbs first.. A pair of 85122+ cost $95 and if it turns out to be burned out projector bowls you can just reuse the bulbs in the replacement projectors
So that is interesting, did not realize the C5's also had shutters. My C6 only has the HID and DRLs. Definitely not as bright as the C5 when on high beam but I don't get the same diffraction (actually don't notice any color band). Probably could use the EvoX's more on that one.
I also didn't realize that. I guess I've always assumed just the halogen light popped on because it washes out the lighter blue color so much more. Good information to have though. I think my bulbs may be on the way out since I briefly see a brownish/pinkish tint when they first kick on.
#20
