Found oil in all spark plug wells... What now?
How do you know that the oil is leaking where your have added the arrow? IMO it is unlikely.
Remember, the oil pressure and cam movement will push a lot of oil around that space and the dried out (at 100k miles) valve cover gasket simply won't keep the oil where it belongs.
The leak is most likely coming from the top of the spark plug tube, which will be sealed by a new valve cover gasket. If you install the gasket (and it isn't pinched or off center) and it still leaks then you will need to do some research to find the answer.
Good luck.
Good luck.
Good luck.
Good luck.
I'm going to take that coil pack out and confirm...if it is, oh well. Maybe a small dab of sealant inside the spark plug tube for a temp patch or no?
r1 - did you happen to look further into your theory?
I'm going to order another set of gaskets and take it all apart again. Hopefully I've just pinched a gasket, or maybe I used to much RTV sealant? Do you even think I need to use RTV?
That is the cam bearing/upper cylinder head. Theres no gasket. Its silicone sealer. You really should remove the timing belt when you remove that because it can do strange things to the cams with all the belt tension on and cams not bolted down. Remove bolts, pry it off. Its tuff, and clean everything super good and use like Ultra Grey or Ultra black RTV, VERY small amount, remember theres like almost NO clearance when its bolted down so a small layer is squished to almost nothing.
#18
If you used any at all, you used too much.
Clean that crap up and try a new gasket unless you are fairly sure the leak is coming from further below. Personally, I doubt that the lower gasket is the issue if you got oil in the plug wells that quickly. Sounds like the leak is worse not better?
#19
You mean chain, not belts?
#20
