Throttle delay...lag...whatever, is driving me nuts.
#101
#102
Did you observe this ONLY in corners, or did you also try the "slowing almost to a stop, then try to accelerate" test in a straight line?
Strange that this seems to go away in manual mode (suggesting a tranny ECU issue), but those with tunes have reported that the tune also eliminates this (with no changes to tranny ECU). I wonder if those with a tune are simply more likely to use manual mode and so didn't notice that the issue is still there if in auto?
#104
#105
It doesn't matter what mode I'm in, I never get instantaneous throttle response. If you do, then maybe this isn't a software problem, but a hardware problem that can be fixed.
#106
I too have felt the lag. There was one issue where I went to take a left in front of an oncoming car. I turned the wheel and hit the gas and NOTHING! My heart sank and I thought what the hell was going on, then it took and I shot off to the left but not after full panic mode.
There are issues with this car and throttle lag. My service rep said there were no repair bulletins so nothing they could do.
I guess I have learned the car well enough, that I know "how" to drive the car. This isn't right, and I have concern when my wife decides to drive this car. For example, I put the tranny in dynamic when merging onto the highway. In traffic and needing to jump between lanes or at least to make sure the car wild respond, I put in dynamic.
If there is no traffic and I am just driving, I put it in normal drive, knowing that lag is there.
This is definitely a software throttle mapping issue and it can be fixed. Hopefully they will issue a repair bulletin soon. In the meantime, I just manage the lag
#107
Does anyone know if the APR tune eliminates this in D mode? As I mentioned before, I almost got clipped the first time I experienced this trying to get around in traffic and experienced the lag followed by a jump when the power kicked in.
#108
Any chance this is related to cylinder De-Activation?
The car has to, at some point, re-engage the other 4 cylinders before it can respond with full throttle
.... Just thinking outloud
#109
Just wanted to share some results from some quick testing I did at lunch: this was all done with the wheel essentially straight, and in manual mode. Also, for what it's worth, I have all settings set to "Dynamic" except the seat belt tensioner.
3rd gear: noticable lag when slowing to <2000 RPM, then applying throttle at a constant ~25%. No RPM climb, no acceleration at all for 1-2 seconds. After 1-2 seconds, RPMs begin climbing and car begins to accelerate.
2nd gear: same as above.
1st gear: did NOT observe this lag when in 1st gear. Experimented the least in this mode, as traffic conditions didn't warrant slowing that much. Did three tries, and observed no lag. Can anyone else confirm this result? I'll try again on the way home from the office.
#110
Good idea, though, if anyone has any other thoughts by all means post them up!
