1990 Audi CQ Running Rich
Old 08-04-2011, 09:05 PM
ufoforever's Avatar
Default 1990 Audi CQ Running Rich
Hi, I'm new to this forum. I have a 1990 CQ and I have been experiencing problems. I have a code 2341.
The car was running great, then one day it went into limp-mode. Found out the fuel pressure supply line was leaking, so I fixed it. The car started running awful, so I did a tuneup, replaced the cap and rotor, all new spark plugs, and a new bosch fuel filter. Still had an issue, so I traced it to a bad fuel injector. Next I replaced all the injectors with the 034 motorsports fuel injector upgrade. Following that I still had a CEL.
So now, I am stuck. I still get a 2341 code (translated to 02 sensor control limit exceeded). I experience slightly longer starting time, somewhat fuel odor, and limp-home mode. The fuel pressure gauge I installed recently shows a residual 40psi which eventually drops to zero. At idle the pressure is 43-44 with vacuum, and without vacuum the pressure goes at most 54-55psi.
Does anyone have any ideas? I am automotive graduate, but brand new to Audi, let alone the rare 90' CQ.
Old 01-27-2012, 06:41 AM
x19
x19's Avatar
Default 1990 audi CQ code 2341
I am wondering that did you fix your problem ? or adjust CO mixture? or other thing ? x19
Old 01-27-2012, 12:02 PM
ufoforever's Avatar
I haven't narrowed the problem further, although I am burning rich, oil smells like rich mixture. I did replace the rear coolant sensor on the firewall side of the motor, and that helped much, but the problem persists.
Old 02-24-2012, 03:13 PM
Solid20vq's Avatar
When I first got my 90quattro 20v I had very long crank times and power issues. The Audi tech diagnosed it as a bad fuel pressure regulator, which was causing a mixture so rich it destroyed the O2 sensor. I had to source the part from a 200. I can provide the PN if it sounds like something you'll need.
Old 05-10-2012, 10:20 AM
x19
x19's Avatar
Code 2341,
Probably, you have to look the operation of 02 sensor when you could start engine, Here is how to probe the 02 and hook up either teat wire of DVM to 02 wiring to( insert wire between or connection on 02 wiring = Green and black wire) and other test wire of DVM goes to chassis ground with setting DC Volt scale. You will see the voltage and should see 0.2 ~ 0,8V fluctuated with idling even engine raised high RPM. if you see the voltage that I listed, furl mixture is OK. Out of CO adjustment makes hard to start too. x19
keithsan
A4 (B7 Platform) Discussion
9
03-28-2013 09:02 AM
ufoforever
14
08-24-2011 10:48 AM
robocik74
2.0T FSI Discussion
03-24-2011 01:44 AM
Monkeyboy
07-04-2007 03:51 AM
Aussieguy
02-26-2003 02:35 AM
Quick Reply: 1990 Audi CQ Running Rich
