Old 07-22-2016, 01:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B7) Interior Guides
Print Wikipost
Aftermarket Bluetooth that uses OEM steering wheel buttons! !
Old 09-27-2006, 08:07 PM
RKJ
RKJ's Avatar
Default Re: About the menu...
The information display just says "PHONE" as does the radio display.
The Parrot 'talks' to you.
For example...When you access the settings it says "Language-English". Scroll the right thumbwheel and it talks in French, Itallian, etc.
Tap the right button and it moves to the next option, volume.
The parrot says "volume" and pings every few seconds so you have a tone to set the volume by.
The other menues all work the same. It's kinda cool not having to read a display.
Keep us posted on your install and impressions!
Robert
Old 10-10-2006, 06:18 PM
GMCountry's Avatar
Default I finally received the package. I'm installing it onto a retrofitted RNS-E.
The whole assembly looks pretty complicated with all the adapters and wires, but I'm sure it'll work out. I'll probably start tackling it this weekend.
Old 11-03-2006, 06:40 AM
PurpleAudi's Avatar
Default Re: Aftermarket Bluetooth that uses OEM steering wheel buttons! !
Is this still being recommended? Looks interesting.
Old 11-09-2006, 05:41 AM
PurpleAudi's Avatar
Just got it and installed it. Wow! Works great. Thanks for the terrific write-up. At first I forgot to connect the ignition fuse holder top to 12V switched and my Parrot didn't power up, but then I figured out my mistake. Highly recommended.
Old 12-19-2006, 12:19 PM
Sanjman's Avatar
Does the Mode button have any functionality now? If not, is it possible to to program the Mode to enter the Parrot Menu instead?
This may be a no-brainer, but I want to make sure: Will I lose the regular functionality of the scrollers (scanning radio stations/volume)?
Or once the radio goes into "Phone" mode, does the steering wheel functionality transfer directly to Parrot?
alexzarrabian
07-15-2015 01:24 PM
knepster1
Q7 MK 1 Discussion
01-18-2009 09:10 AM
RKJ
Telematics Discussion
09-13-2006 07:15 PM
ToyCeli22
01-15-2006 01:11 PM
Quick Reply: Aftermarket Bluetooth that uses OEM steering wheel buttons! !
