Old 08-09-2016, 12:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B7) Specifications & General Maintenance
Print Wikipost
Jacks, jack stands, where do I put them? --> jack pointers inside.
Old 04-08-2003, 06:13 AM
  #21
Rest In Peace
markbradford's Avatar
Default Heh. Once you've got the DTS in it's even easier.
There's an area with a detent where the large bolt is in the middle that's captured by a rim of aluminum, so the jack stand can't slip or anything. Solid and secure as hell.
Old 04-08-2003, 06:15 AM
  #22
Rest In Peace
Default And yeah, the pad where Andy has his rear jack stand is the area I'm talking about.
Similar up front as well.
Thing is, I can't put my jackstands there cause they have curved tops, so they'd exert too much pressure in acute areas. It looks like Andy's are flat, making it much easier for him to find a spot to put them.
Old 04-08-2003, 06:46 AM
  #23
AudiWorld Expert
Digit@lex's Avatar
Sweet. Thanks again.
Old 04-08-2003, 06:48 AM
  #24
AudiWorld Expert
Digit@lex's Avatar
Can I use rhino ramps during my DTS install or will it get in the way?
Old 04-08-2003, 06:52 AM
  #25
Rest In Peace
Default Rhinos will be OK for sure. I can't get up on them tho. =(
Not sure if they'll be high enoguh for you to get under there though will they?
Old 04-08-2003, 07:01 AM
  #26
AudiWorld Expert
Digit@lex's Avatar
Default Barely...
I got it up there last year but I was literally touching the ramps. If my suspension hasn't settled down any more I should be able to make it up. *fingers crossed*.
Old 04-08-2003, 07:04 AM
  #27
Andy_FL's Avatar
Default You could always use a little creativity to get onto the ramps....if needed.
Somehow create a gradual step up to the ramp. I've seen people lay down short pieces of 2x4 (or maybe even thinner pieces) in front of the ramps....that might be just enough to lift the front end enough so it clears. Good luck
Andy
Old 04-08-2003, 07:09 AM
  #28
Rest In Peace
Default No I mean - will you be able to get your body under the car with enough room to work?
I don't like rhinos cause I find they don't get high enough. I crank the jackstands WAY up so I can get some leverage'
Old 04-08-2003, 07:12 AM
  #29
AudiWorld Expert
Digit@lex's Avatar
Default I see what you mean.
I guess it depends if I need to be directly underneath the car when I'm torquing down the bolts. I was thinking that I can install it from the sides and not be directly underneath the car.
Hmmm, that's a good point. Were you more than halfway underneath the car? You must be hyooge. ;-)
Old 04-08-2003, 07:13 AM
  #30
AudiWorld Expert
Digit@lex's Avatar
Thanks. I need to do that now to get on some lifts. :-)
Quick Reply: Jacks, jack stands, where do I put them? --> jack pointers inside.
