Old 08-09-2016, 12:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B7) Specifications & General Maintenance
Print Wikipost
Jacks, jack stands, where do I put them? --> jack pointers inside.
Old 04-07-2003, 08:14 PM
Member
Pizzicato's Avatar
just to the inside of it
Old 04-07-2003, 08:21 PM
CMC
CMC's Avatar
Default What's that undercoating made of? I got a chunk taken out earlier this week driving into a parking
lot made for 4x4's out by the Ozarks. =(
Any idea where I can get it "recoated"? Thanks...
Old 04-07-2003, 08:31 PM
Andy_FL's Avatar
Default Rubber?
A rubbery/sticky goo? Just grab a spray can of rubberized undercoating (or truck bed liner) at AutoZone....it's nasty stuff, but it does the trick. Good luck
Andy
Old 04-07-2003, 08:39 PM
CMC
CMC's Avatar
Default Cool... thanks Andy!!! =)
I'll get working on it sometime this summer and place my jack stands in the spots you stated above, hehehe.
Old 04-07-2003, 08:40 PM
Former Vendor
MikekiM@PureMS's Avatar
Default Excellent pointer
For lifting, I use the flat spot (that's sorta deformed in your pic), BUT I place a small piece of plywood on top of my lift pad. It helps to prevent that are from getting deformed.
I use various places for the stands, where you indicate is an excellent choice, as is where MB suggests on the factory DTS mounting locations.
Old 04-07-2003, 09:02 PM
Greyhound Guy's Avatar
sometimes also known as undercoating.
Old 04-08-2003, 03:08 AM
AudiWorld Expert
Digit@lex's Avatar
Default Mark, can you point out where this PAD area is?
Is it where those little rubber circular pads cover up the holes or somewhere else? Thanks.
Old 04-08-2003, 04:11 AM
  #18
scott12v@pghaudi's Avatar
You should submit this as a FAQ.
Old 04-08-2003, 04:41 AM
  #19
Rest In Peace
markbradford's Avatar
Default Low, square, flat area that does have a hole in it yes.
I use a flattop floor jack to lift there and then put the jack stands where the DTS go. The dealer uses these pads with a lift too, because the surface area is greater to distribute the weight better.
Old 04-08-2003, 04:45 AM
  #20
AudiWorld Expert
Digit@lex's Avatar
Default Cool thanks. I think in the pic, that's where Andy had his rear jack stands placed (last pic).
Ok, I know there is a similar one up front. However, when I jack the front I won't be able to use the DTS area since I will be installing the DTS. ;-)
Quick Reply: Jacks, jack stands, where do I put them? --> jack pointers inside.
