How does one get to the far reaches of the rear window to clean the nastys?
I gave the shade cover a forceful yank but it didn't even budge. Why is it that bugs land in that awkward place?
Re: How does one get to the far reaches of the rear window to clean the nastys?
Either a can of compressed air (used to blast the dust from computer keyboards) or, next time you're at a gas station, give it a blast from the air hose used to refill tires.
A detailer showed me a trick she uses all the time: she has an assortment of
straws and tubes that she tapes to a vacuum nozzle. those little straws can go ANYWHERE, even between the seat and the hump and way into the vents.
If you have a shop vac, get a funnel for adding transmission fluid (small funnel with long skinny tube). Stick the hose in the funnel. Works great (assuming you turn vacuum on).
goohead
04-24-2008 09:03 AM
Zumkopf
10-01-2007 10:07 AM
borden
12-03-2004 06:39 PM
I think I figured out a way to not destroy an use existing plumbing to get more air into the motor.&
0TT0 BURNER
13
06-18-2001 08:21 AM
