Are slotted rotors directional?? Also why would my brake light come on after.
Old 09-26-2005, 04:52 PM
Black Sunshine's Avatar
Default Are slotted rotors directional?? Also why would my brake light come on after.
swapping rotors. The pads are w/o sensors and have been in w/o any problem for about 5k now, I only just swapped out the rotors for new ones.
Old 09-26-2005, 04:56 PM
Audiworld Sponsor
DAP@EPL's Avatar
Default Only the directions of the vanes (if they are directional) matters.
Did you short the pad sensor wires when you put on the pads? Perhaps the wires came loose?
-Dave Pramanik
Old 09-26-2005, 04:58 PM
Default The rears had an R and L on them (written), fronts didn't...
however the vanes on the rears both point back ( \ ) whereas the vanes on the front point ( / ) forward.
I am going to check the wires, they were shorted before.
Old 09-26-2005, 05:28 PM
P. Bauer's Avatar
do you mean vane or slot?
Old 09-26-2005, 05:45 PM
rktskicar's Avatar
Default Is it your brake light or your worn brake light? If it is worn brake light, then check..
brake sensor bypass short in connector.
Bruce
Old 09-26-2005, 05:58 PM
well, slot I guess... they are not curved
Old 09-26-2005, 06:09 PM
P. Bauer's Avatar
Default the vanes are inside the rotor, they are usually swept in one direction.
if you hold the rotor up and look down the middle of it, the vanes will be slanted one direction..
on the driver's side, you want to the vanes like this:
Old 09-26-2005, 06:11 PM
Check, I'm golden... now just the stupid light.
Old 09-26-2005, 06:13 PM
P. Bauer's Avatar
Default take your old sensors off the old pads.
cut the wire, twist it together and heat shrink or tape it, then plug it back in. It will never show the wear light again.
sarasotas4
10-08-2008 07:12 AM
secreTTasianman
9
07-20-2006 06:18 PM
AwdiA4
01-20-2005 05:42 AM
CMS4
05-03-2004 01:32 PM
SpfldS4
20
04-20-2004 09:27 AM
Quick Reply: Are slotted rotors directional?? Also why would my brake light come on after.
