Aircon intermittent
Old 03-29-2014, 08:41 PM
Tyson2busy's Avatar
Default Aircon intermittent
Hi Guys,...
My air con compressor will come on every once in a while, then cut out. So I know it works, but what could be causing this?
Thanks
Old 03-30-2014, 11:24 AM
Rusty Spokes's Avatar
Originally Posted by Tyson2busy
Hi Guys,...
Thanks
Don't know what year model Audi..90..Cabriolet..but they work pretty much the same.
Could be low on refrigerant..compressor comes on and the low side pressures drop below the threshold of the low pressure switch..then the compressor kicks off..low side pressure comes back up..compressor come back on line and engages.
An over charged system will do it too. High side pressure switch kicks the compressor out when the high side pressures go up.
Some A/C gauges and an low side adapter (yellow jacket #19153 ACME FEMx13mm) on the compressor port will tell the story.
Old 03-31-2014, 02:55 PM
Tyson2busy's Avatar
Interesting! Wow,..talk about a complicated system!
Thanks!
Old 04-01-2014, 02:35 PM
hubturn's Avatar
There is also a thermal switch that will shut off the compressor if ambient temperature is too cold. If you are in the north country, it may still be too cold.
Old 04-02-2014, 06:10 PM
x19
x19's Avatar
What kind of refrigerant is in system R-12 or R134a?
In either way, lower refrigerant in system is doing this and check the leakage in system if you can
or let professional tech do the evacuate and recharge system with right freon gas includes leakage test. x19
Old 04-05-2014, 04:27 AM
egp320i's Avatar
Sounds low, I had the same issue.
You should run the AC in the winter once in awhile to leg the PEG oil keep the seals lubed, helps to cut down on leakage.
Evac and recharge fixed the issue.
scoutii304
Audi 100 / A6 (C4 Platform)
07-16-2012 08:00 PM
vtraudt
06-12-2012 07:31 AM
EAustin494
08-03-2005 06:42 PM
Audi Logic
07-15-2004 10:27 AM
liz
11-05-2002 09:11 AM
Quick Reply: Aircon intermittent
