so I bought the '93 90 cs quattro that I traded for '00 a6 4.2l
Old 03-27-2014, 11:26 AM
goodys90's Avatar
Default so I bought the '93 90 cs quattro back that I traded for '00 a6 4.2l for $500
Got it home noticed water pump was leaking looked in coolant tank noticed oil residue replaced water pump thermostat all gaskets head gaskets freshened from bottom to top anyway get it all back together fluids in all wired up correctly go to start no start. Loud buzz comes from fuel pump relay nothing from pump. Took relay out and bypassed it pump starts pumping got new relay same thing. Any suggestions?
Old 03-28-2014, 01:33 PM
CRAZY_RUSSIAN's Avatar
hows the ignition switch?
Old 03-28-2014, 06:31 PM
x19
x19's Avatar
Did you check the power at the relay terminal(base) and( (or) ground on engine side?
Old 03-28-2014, 09:21 PM
goodys90's Avatar
Just to make sure the ground that's on engine mount goes to goes to a spot on passenger side under air box on bottom side of frame right? Car was partially torn apart when I bought it back wasn't quite sure
Old 03-28-2014, 09:26 PM
goodys90's Avatar
And also to make sure the wires that go to alternator and starter if they were connected to the wrong one it wouldn't Evan turn over would it. just another dumb ? Probably but just making sure
Old 03-31-2014, 04:18 PM
x19
x19's Avatar
Did you check the valve timing and compression and fuel is coming out to cold starter vale etc.
Can you start engine(or cranking?. ) with remote starting switch or bypassing the wiring on stater (ignition switch must be on position, plus park and brake on!) and watch the spark or.
Old 04-01-2014, 06:53 PM
goodys90's Avatar
It turns over. Replaced fuel pump relay again now I got fuel other one must have been a faulty relay. So now the only thing I don't have is spark
Old 04-01-2014, 11:18 PM
goodys90's Avatar
Its running!!!!
MacEwen
10-30-2016 11:03 PM
A6CAVAN
11-23-2009 05:56 PM
patf
11-19-2006 08:02 PM
Joshv8q
08-10-2005 09:54 AM
Khris
Audi 100 / A6 (C4 Platform)
18
03-20-2004 08:48 AM
Quick Reply: so I bought the '93 90 cs quattro that I traded for '00 a6 4.2l
