88 NG 90q driveablilty/timing 2 issues
Old 02-24-2014, 07:33 AM
Maine90q's Avatar
Default 88 NG 90q driveablilty/timing 2 issues
First off, hi there. 88 90Q with an NG up here in Maine. I was a member a LOOONG time ago, with an email address I havent been in in 2 years (and different 80's audis, coupe GT, 5K avant q, another 90q etc.). So I had to re-register.
My 88's issue is this. Around a month ago I hit a puddle and the engine bogged down something fierce. Pulled the Timing 2 fuse and it came back to life, albeit with reduced power. Dried out for the weekend, put timing 2 fuse back in. Drive for a few days, no issue. CEL comes on on the highway, get off my usual exit, bogs down (not wet out). Pull timing 2, gets me home. Checked CEL, flashes code 1-1-1-1. try to start with T2 fuse pulled, no go. Now it seems like every time I start it, once it warms up I have to pull the timing 2 fuse and limp around. Coolant temp sensor for ecu replaced (the one underneath) last week, no vac leaks, hall sensor connector was soft, I repaired that. New plugs, wires, cap, rotor done recently just as routine maintenance. Synthetic since new, was well cared for. This is just frustrating. Thanks in advance for the tips
Old 02-25-2014, 09:20 PM
CRAZY_RUSSIAN's Avatar
whats 1-1-1-1? i dont know the codes for the I5 engine
Old 02-26-2014, 07:24 PM
varia's Avatar
Flash Code 1111
Fault Source Control unit
Symptom Engine does not start
Possible Cause - Fault in control unit ground wiring
- Microprocessor in MPI control unit is faulty
Fault Correction - Check ground connections
- Replace MPI control unit
Old 02-27-2014, 12:07 PM
x19
x19's Avatar
Code 1-1-1-1 (nothing wrong) on this engine is normal and varia mentioned already, check the wiring from ECU to every sensor , connection and ground circuit includes engine to negative of Battery.
Old 03-03-2014, 06:28 AM
Maine90q's Avatar
Thanks all, it ended up being a bad wire to the ect and a bad ground to the block!
Running great now, no codes
Old 03-12-2014, 04:37 AM
x19
x19's Avatar
Nice to hear! x19
Old 03-12-2014, 07:15 AM
Nice
where in Maine are you?
chubs636
TT (Mk1) Discussion
09-14-2015 03:42 PM
Delsol67inamsterdam
Audi A3 / S3 / RS 3 MKII
09-13-2015 09:18 PM
cbpdpm
S6 (C7 Platform) Discussion
09-12-2015 10:02 AM
RTnDL
09-07-2015 11:17 AM
sethm1
Audi A3 / S3 / RS 3
09-04-2015 04:01 PM
Quick Reply: 88 NG 90q driveablilty/timing 2 issues
