Newbie Audi 80 2.6 cold start problem
Old 06-18-2011, 02:39 AM
  #11
alsies's Avatar
Default Further update
OK, it's really annoying me - it's still taking 2-3 times to start each morning or after it's been sitting for half a day.
I've cleaned the ISV, checked the fuel injectors today - no leaks - and have also double-checked the vacuum system (I checked the vacuum pressure just forward of the 3-way vacuum check valve in the morning and there was still vacuum pressure - a 'hissing sound' and sucking air for about 5 seconds). This vacuum pressure line led back into the passenger compartment.
I've ordered a code scanner to see what it reveals (the ebay cable thing wasn't very successful!).
Hmmm....
Old 06-18-2011, 08:39 AM
  #12
Lago Blue's Avatar
Default Starting with more questions...
Does your car have:
- a MAF; or a MAP type air-flow sensor;
- an EGR System;
- My question here is really, are the pollution controls always grouped together the same way, i.e. all (cats, EVAP etc.); or none?
I agree with LoudGold that it may be some sort of air leak, - how much vacuum does your engine pull at cold idle? But perhaps not necessarily vacuum though, how about un-metered air leaks such as:
- how's your Noise Damper to throttle-body gasket? See also the "telephone cord mod". Is the Damper cracked or missing hoses?
- OEM Cam-cover to Noise-Damper vent hoses cracked?
- Air meter to throttle-body air flex-hose loose/cracked/leaking seals?
- Adapter block for ISV to Intake-Manifold rubber coating crumbling?
Old 07-20-2011, 02:01 AM
  #13
alsies's Avatar
Alright, I had a look at the relays as I read somewhere that sometimes the solder joints on some of the relays may be weak and need to resoldered. I found 1 relay with a few suspect solder joints and resoldered them. The car started first time each time for the next week or so. I then replaced the old spark plugs NGK BKUR6ET-10 with Iridium ones NGK BKR6EIX-11 and now have the old start problem before although not as severe.
Your thoughts on these Iridiums? Should I go back to the BKUR6ET-10? Is there a known issue with these Iridiums?
Thanks.
Originally Posted by Lago Blue
Does your car have:
- an EGR System;
Old 07-20-2011, 05:55 AM
  #14
Loudgoldwing's Avatar
Iridiums are no good for these cars. The element is too small, causing too focused of a spark for the gas to ignite properly. Your car has "A-class" 2-hole injector nozzles that don't usually atomize as well as the upgraded "E-Class" 4-holers.
Go with good old standard NGK's or Bosch plugs for about $20. Or, look for a set of "E-Class" injector nozzles for $200.
Old 07-21-2011, 01:30 AM
  #15
alsies's Avatar
Thanks for the advice - I'll switch back to the old NGKs on the weekend.
Cheers!
Old 08-06-2011, 10:39 AM
  #16
Lago Blue's Avatar
Default Re: Vacuum measurement...
The vacuum that may be more critical for starting is that which can be measured right at the small Intake-manifold connection nearest the Fuel Pressure Regulator when the engine is warm at idle. This is both an indicator of what can be delivered to the FPR; and also tell you if intake-air is bypassing the air meter, throttle and ISV.
BTW, I'm very happy with my NGK Iridiums in my 12v, the p/n I'm using may be different due to mine being a 2.8.
Did you have any luck with this?
Old 11-24-2012, 08:52 PM
  #17
alsies's Avatar
Default Cured???
Well, just to update you all - from the last time I was here until now I replaced the cam position sensor, fuel pump relay (with the updated version) and fuel filter (again!). I also dismantled the throttle body and cleaned it all out.
Then I read on the 'net about people having similar starting issues and that their solution was replacement of the fuel pressure regulator. So I bought a Bosch replacement regulator and replaced it earlier this week. Guess what? All good so far! No problems with starting! *fingers crossed*
Thanks for all your advice in the past!
Old 07-23-2013, 06:07 PM
  #18
alsies's Avatar
Another update: I've had no starting issues since replacing the fuel pressure regulator last year. A relatively cheap fix in the end but to find it was really a guessing game. Thanks again!
Old 03-30-2014, 07:54 PM
  #19
alsies's Avatar
Default Fuel Injectors
Are the upgraded "E" injectors the standard replacement injectors or are they aftermarket ones. Are they worthwhile getting.
05AudiAllroad
Audi allroad
6
05-05-2016 03:52 PM
ihfree
Audi Original "S" Cars
05-06-2009 02:30 PM
NickJ
9
01-20-2009 01:37 PM
audix
30v V6 Discussion
10
07-14-2008 11:28 PM
Mtnboy7
Audi 100 / A6 (C4 Platform)
11-05-2003 06:54 AM
Quick Reply: Newbie Audi 80 2.6 cold start problem
