2002 A6 3.0 Cylinder 4, 5, and 6 Misfire Help??
changed plugs and coils.. changed MAF, seems that the engine light is worse after the install of new Hitachi MAF 0036 from rockauto. Flashing quite often, more than it was before i had the plugs and coils changed then the MAF. Will listen for leak , seems to be this is the next step. still getting all the same codes.
Hi,
First post and just wanted to say thanks for the info. I very much hope that this solution will work for my 2004 3.0 A4. Had intermittent CEL with random misfires on 4,5,6 for some time. New plugs, new coil packs (courtesy of AUDI main dealer on a recall - on a 10 year old car, thumbs up to them), new MAF.
Still the same with now suddenly running rough/stalling at idle/low speed, then OK for a while.
Your description is the closest I've come across in hours of searching.
I await the delivery from China.
Hi,
My issue also did include what felt like a misfire without a flashing cel or any DTC's (tell tails) in vagcom for just a short time
Watch the youtube video as the man clearly shows how to block the port to determine the failure of the CCV, and because of the constant way below freezing temps this winter I suspected that mine was a result of frozen moisture latent oil "tan butter" causing the vacuum hissing because the diaphragm pin was not seating, a real legit CCV failure would be a torn diaphragm and would warrant replacement as I just cleaned my old one and put in the spare parts bin.
Well, yes, the revs definitely increased spontaneously at lights etc and misfire/loss of power. This situation has only occurred a few times and isn't consistent. The only thing that is consistent is that the CEL will nearly always flash occasionally on just about any trip over a few miles, resulting in error code random multiple misfires on 4.5.6 but no loss of power.
Pulled the CCV, full of emulsified oil (lots of short trips). I don't know what the OK state of this is as I've never pulled it before but I cleaned it out and now not getting the actual missing/power loss (just the 4.5.6 error code)
However, I don't know what an OK valve looks like but this one doesn't appear to be right to me... it's wide open, just straight through.
Anyway, new one is on it's way.
If your running good now just clear them.
They are current, have cleared them but they come back
Have now replaced the vacuum valve but still getting random multiple misfires on 4,5,6 accompanied by flashing CEL, although stuttering from lights etc has stopped and no noticeable power loss.
So far:
New coil packs (Audi)
New MAF sensor (Audi)
New vaccumm valve as above
New brake switch (Audi)
New Plugs (Bosch)
Flashing CEL seems to occur randomly, just cruising along steadily and VAGcom then reports misfires.
At a loss, only thing I can think of is a possible slight vacuum leak somewhere.
So far:
New Plugs (Bosch)
#18
So far:
New Plugs (Bosch)
So far:
New Plugs (Bosch)
Can you post the vagcom DTC's?
levansula
24
01-26-2021 04:02 AM
SchwarzY2kS4
Want To Buy - Archive (NO NEW POSTS HERE)
11-19-2015 04:53 PM
eagledubg
09-29-2015 12:35 PM
