What is included in first service
Just got my car from first service, 5k. My oil level is really close to min, at about a quarter of the bar. The car was returned dirty, not washed. Just wondering whether oil change is included and if so what is the correct level of engine oil after the service. Also, do you get your vehicles washed after the service?
You can find the Audi Maintenance Schedules here: http://www.audiusa.com/us/brand/en/o...intenance.html
Here's what should be done in first service:
Engine Oil/Oil Filter – change oil and replace filter
Tires and Spare Wheel – check for wear and damage, check tire pressure, reset Tire Pressure Monitoring System (TPMS)
Tires – rotate, reset TPMS
Wiper Blades – check condition and replace if necessary
Wiper/Washer/Headlight Washer – check adjustment and function, add fluid if necessary
Service Reminder Display – reset
Brake System – check for damage, leaks, pad thickness, fluid level
Wanna bet? My oil and filter were changed at 5K.
http://microsites.audiusa.com/ngw/11...rt_2011_J2.pdf
