Update MMI = Chassis Number Deleted
Old 04-16-2014, 05:45 AM
darkdll's Avatar
Default Update MMI = Chassis Number Deleted
Hi, I've updated the MMI on my A7 (it's a 3G + system) from the HN+_EU_AU_P0160 to HN+R_EU_AU_K0770 and everything works fine except the chassis number, seems to have been deleted, I get this message when I access it:
Any help is appreciated
Old 07-27-2014, 09:38 AM
intel66's Avatar
Got exact same problem. Found any solution?
Old 12-22-2014, 04:14 PM
darkdll's Avatar
Solved, this is caused by activating new maps with carson method, when you update the MMI version or reinstall the map the chassis number back to normal.
Old 01-01-2015, 10:03 AM
siren001's Avatar
Where did you get your MMI update from?
Old 04-19-2015, 07:02 AM
intel66's Avatar
Did not work in my case; unable to upgrade MMI because I already have newest version 783 ("start upgrade" option grayed out in menu).
Same problem with maps (version 6.20.4).
Old 04-19-2015, 07:14 AM
snagitseven's Avatar
They are from outside of North America. Different MMI versions.
Old 04-20-2015, 06:24 AM
darkdll's Avatar
You can do an "emergency update" using the green menu, this will reinstall the MMI firmware but you will lost your carson activation and map will don't work.
Old 04-20-2015, 10:19 PM
intel66's Avatar
If I downgrade MMI firmware, install Carson patch and upgrade firmware again the normal way (without green menu). Do you think it will work?
Thanks.
surflj
Q7 MK 1 Discussion
08-21-2016 06:56 PM
radman2020
Q5/SQ5 MKI (8R) Discussion
20
11-12-2015 09:48 AM
fender4645
A6 (C7 Platform) Discussion
02-28-2013 01:55 PM
airbil
04-21-2010 05:37 PM
skabaru
03-25-2003 10:30 AM
Quick Reply: Update MMI = Chassis Number Deleted
